Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Inspect the damage and mark any broken boards that need to be replaced using painter's tape.
Measure and estimate the new boards you need to purchase.
Measure the replacement pieces.
Put the broken board on the new board and mark the angle it should be cut at on both sides.
Draw the line by connecting the marked points.
Use a hand saw to cut along the marked cutting line for each new board.
Mark up screws position on each new boards.
Line up the boards and mark the length where the screws should go.
Measure the position of the screws from the edge on the old boards and mark the same position on the new boards.
Pre-drill the holes at the marked spots using a 1/8th inch drill bit.
Drive screws into the pre-drilled holes.
Use a wet scrubbing sponge to clean up the lines.
