Ana içeriğe geç
How to Replace Concealed Cabinet Hinges
Neye ihtiyacın var
  1. How to Replace Concealed Cabinet Hinges, Hinge: adım 1, 3 resimden 1. How to Replace Concealed Cabinet Hinges, Hinge: adım 1, 3 resimden 2. How to Replace Concealed Cabinet Hinges, Hinge: adım 1, 3 resimden 3.
    • Remove the screws that are attached to the cabinet door.
    • Unscrew the top and bottom hinges even if you are only replacing one hinge.
    • Remove the cabinet door from the hinge.
    • You may need to wiggle or pry the door off.
  2. How to Replace Concealed Cabinet Hinges: adım 2, 2 resimden 1. How to Replace Concealed Cabinet Hinges: adım 2, 2 resimden 2.
    • Remove the screws that go into the cabinet frame from the hinge, then remove the hinge.
    • Only the hinge being replaced needs to be removed.
  3. How to Replace Concealed Cabinet Hinges: adım 3, 3 resimden 1. How to Replace Concealed Cabinet Hinges: adım 3, 3 resimden 2. How to Replace Concealed Cabinet Hinges: adım 3, 3 resimden 3.
    • Insert the new hinge into the cabinet door's pre-cut hole.
    • Attach the hinge with the provided screws.
    • To avoid striping the screws, do not over tighten.
  4. How to Replace Concealed Cabinet Hinges: adım 4, 1 resimden 1.
    • Reattach the cabinet door to the cabinet frame.
    • Do not tighten the screws all the way. You will need to align the door later.
    • You may need a friend to hold the door while you screw it back into place.
  5. How to Replace Concealed Cabinet Hinges: adım 5, 2 resimden 1. How to Replace Concealed Cabinet Hinges: adım 5, 2 resimden 2.
    • Lift or lower the cabinet door to align the hinges with its original location.
    • Changes in wood stain can serve as a useful alignment guide.
    • Tighten all the screws.
  6. How to Replace Concealed Cabinet Hinges: adım 6, 3 resimden 1. How to Replace Concealed Cabinet Hinges: adım 6, 3 resimden 2. How to Replace Concealed Cabinet Hinges: adım 6, 3 resimden 3.
    • Use this step to adjust the amount of space between the cabinet door and the cabinet frame.
    • Loosen the adjustment screws, but do not remove them.
    • Slide the cabinet door to your desired position.
    • Tighten the screws.
  7. How to Replace Concealed Cabinet Hinges: adım 7, 1 resimden 1.
    • Use this step if your cabinet door closes too hard or does not completely close.
    • Tighten this screw to keep the cabinet door from closing too hard. Loosen the screw to allow the cabinet door to close completely.
    • Do not completely remove this screw.
Bitiş Çizgisi
4 farklı kişi bu kılavuzu tamamladı.
Naomi Frazier
171 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team S4-G4, Cole Spring 2017 UC Davis, Team S4-G4, Cole Spring 2017 üyesi
UCD-COLE-S17S4G4
3 Üyeler
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 21
Son 30 gün: 83
Her zaman: 27,859
