Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Use a painter's tool or putty knife to remove the grout from around the cracked tile.
Using an edge or corner of your painter's tool or putty knife, scrape the grout along the perimeter of the broken tile.
Use the painter's tool or putty knife to pry up the broken tile.
If the tile does not lift, place an old rag over the tile and use the hammer to break the tile into smaller pieces.
Remove the broken pieces of tile, using gloved hands for large pieces or a broom for smaller shards.
Using the painter's tool or putty knife, scrape the grout from the edges of tile and any adhesive from under the tile.
Apply new adhesive using the trowel, making sure the adhesive is spread evenly.
Drag the toothed end of the trowel across the adhesive to create even rows.
Place the new tile down in the center of the empty space.
If available, use tile spacers to ensure proper placement.
Allow the adhesive to dry based on the instructions provided on the product.
After the adhesive has dried, add water to a small amount of grout until it's the consistency of toothpaste.
Fill in the area around the new tile, making sure the new grout matches the height of the surrounding grout.
Use a moist sponge to wipe diagonally across the tile, cleaning off excess grout after each wipe.
If any bubbles or gaps form in the grout while removing excess, add more grout and repeat the cleaning process.
Wait and allow grout to dry for several hours.
8 farklı kişi bu kılavuzu tamamladı.
