Giriş
Is the trim around your door damaged or missing due to accidents, wear, or overeager pets? Use this guide to quickly replace sections of door trim.
If necessary, remove the old trim from the door.
With a hammer or pry bar, gently but firmly pry the old trim off the wall.
Start from the corner, and work along the length of the trim.
Using trim nails, nail the trim to the wall, starting from the top.
Align each nail so it is perpendicular to the surface, and hammer it in with smooth, forceful strikes.
Nail along the inner edge as well as the outer edge.
The nails should be placed 18 to 24 inches apart along each respective edge.
A small dab of joint compound or spackling will hide the nail holes.
Place a small amount of spackling (about the size of a BB) on the tip of a finger.
Press the spackling into the nail hole.
Wipe across the top of the filled hole with a putty knife or any flat blade to remove excess spackling.
Well done! Enjoy your door's new look.
6 farklı kişi bu kılavuzu tamamladı.
One Comment
If replacing a single section of old trim bring section of old trim to the store to match pattern and when doing stained wood have the store clerk try to match the stain.
