Ana içeriğe geç
How to Replace Field Hockey Stick Grip Tape
Neye ihtiyacın var
  1. How to Replace Field Hockey Stick Grip Tape, Grip Tape: adım 1, 3 resimden 1. How to Replace Field Hockey Stick Grip Tape, Grip Tape: adım 1, 3 resimden 2. How to Replace Field Hockey Stick Grip Tape, Grip Tape: adım 1, 3 resimden 3.
    • Use a cloth and an anti-bacterial spray to clean the Field Hockey stick.
  2. How to Replace Field Hockey Stick Grip Tape: adım 2, 3 resimden 1. How to Replace Field Hockey Stick Grip Tape: adım 2, 3 resimden 2. How to Replace Field Hockey Stick Grip Tape: adım 2, 3 resimden 3.
    • Unravel the old sticky tape starting from the top of the stick.
  3. How to Replace Field Hockey Stick Grip Tape: adım 3, 3 resimden 1. How to Replace Field Hockey Stick Grip Tape: adım 3, 3 resimden 2. How to Replace Field Hockey Stick Grip Tape: adım 3, 3 resimden 3.
    • Unravel old tape until it meets the end of the handle.
  4. How to Replace Field Hockey Stick Grip Tape: adım 4, 2 resimden 1. How to Replace Field Hockey Stick Grip Tape: adım 4, 2 resimden 2.
    • Carefully cut the tape so that end of grip tape below can be taken off.
    • Handle scissors with care never holding the open blade.
  5. How to Replace Field Hockey Stick Grip Tape: adım 5, 3 resimden 1. How to Replace Field Hockey Stick Grip Tape: adım 5, 3 resimden 2. How to Replace Field Hockey Stick Grip Tape: adım 5, 3 resimden 3.
    • Unravel the old grip tape from the top of the stick that spirals down.
    • Stop unravelling once loose-end cap is exposed fully.
  6. How to Replace Field Hockey Stick Grip Tape: adım 6, 2 resimden 1. How to Replace Field Hockey Stick Grip Tape: adım 6, 2 resimden 2.
    • Put glue around the circumference of the base of the loose cap.
    • Line up and press the cap back onto the stick.
    • Handle glue with care so as not to spill.
  7. How to Replace Field Hockey Stick Grip Tape: adım 7, 1 resimden 1.
    • Let the glue dry for at least 10 minutes.
  8. How to Replace Field Hockey Stick Grip Tape: adım 8, 3 resimden 1. How to Replace Field Hockey Stick Grip Tape: adım 8, 3 resimden 2. How to Replace Field Hockey Stick Grip Tape: adım 8, 3 resimden 3.
    • Using new gauze tape, re-wrap the stick applying pressure in an upwards motion.
  9. How to Replace Field Hockey Stick Grip Tape: adım 9, 2 resimden 1. How to Replace Field Hockey Stick Grip Tape: adım 9, 2 resimden 2.
    • Once new gauze covers the handle, cut the tape from its source.
  10. How to Replace Field Hockey Stick Grip Tape: adım 10, 3 resimden 1. How to Replace Field Hockey Stick Grip Tape: adım 10, 3 resimden 2. How to Replace Field Hockey Stick Grip Tape: adım 10, 3 resimden 3.
    • Secure the gauze with sticky tape at the top of the handle.
    • Cut the sticky tape from its source before wrapping around the top of the handle.
  11. How to Replace Field Hockey Stick Grip Tape: adım 11, 3 resimden 1. How to Replace Field Hockey Stick Grip Tape: adım 11, 3 resimden 2. How to Replace Field Hockey Stick Grip Tape: adım 11, 3 resimden 3.
    • Secure the gauze with sticky tape at the bottom of the handle.
    • Cut the sticky tape from its source before wrapping around the bottom of the handle.
  12. How to Replace Field Hockey Stick Grip Tape: adım 12, 1 resimden 1.
    • Enjoy your new grip tape!
Bitiş Çizgisi
Sophia Juan
205 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 1-5, Andersen Winter 2024 UC Davis, Team 1-5, Andersen Winter 2024 üyesi
UCD-ANDERSEN-W24S1G5
3 Üyeler
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 223
