Ana içeriğe geç
How to Replace Hot and Cold Water Pipes for a Washer
Neye ihtiyacın var
  1. How to Replace Hot and Cold Water Pipes for a Washer, How to Replace Hot and Cold Water Pipes for a Washer: adım 1, 1 resimden 1.
    • Before starting this guide, shut off your water to the washer and dryer. In this guide, valves are used. Some newer setups may use levers.
    • Mark the hot and cold water pipelines with a marker for proper visuals.
    • Hot water
    • Cold water
  2. How to Replace Hot and Cold Water Pipes for a Washer, Disconnect the pipes: adım 2, 3 resimden 1. How to Replace Hot and Cold Water Pipes for a Washer, Disconnect the pipes: adım 2, 3 resimden 2. How to Replace Hot and Cold Water Pipes for a Washer, Disconnect the pipes: adım 2, 3 resimden 3.
    • Using an adjustable wrench, disconnect the pipes carefully from the water supply side and the washer side.
    • After the pipes are disconnected, re-check the leakage and rust in the washer installation.
  3. How to Replace Hot and Cold Water Pipes for a Washer: adım 3, 1 resimden 1.
    • Rotate the adjustable wrench in a counter-clockwise direction to loosen the pipe connection.
    • Make sure to remove the old white Teflon tape. Use a bucket and a piece of cloth for water damps from the connection.
  4. How to Replace Hot and Cold Water Pipes for a Washer, Prepare the new pipes: adım 4, 1 resimden 1.
    • Set up the new pipes to be installed.
    • Check for blockage or any cracks in the valve.
  5. How to Replace Hot and Cold Water Pipes for a Washer, Wrap new Teflon tape: adım 5, 1 resimden 1.
    • Wrap the new piece of Teflon tape around the shut-off valve connection.
  6. How to Replace Hot and Cold Water Pipes for a Washer, Install the new pipes: adım 6, 3 resimden 1. How to Replace Hot and Cold Water Pipes for a Washer, Install the new pipes: adım 6, 3 resimden 2. How to Replace Hot and Cold Water Pipes for a Washer, Install the new pipes: adım 6, 3 resimden 3.
    • Install and connect the new pipes using an adjustable wrench.
  7. How to Replace Hot and Cold Water Pipes for a Washer, Return the water supply: adım 7, 2 resimden 1. How to Replace Hot and Cold Water Pipes for a Washer, Return the water supply: adım 7, 2 resimden 2.
    • Rotate the pipes in a clockwise direction to tighten up.
    • Turn on the water supply. Perform a quick wash and check the connection.
Sonuç
  • This guide contains easy steps of instructions to be followed if your pipes of the washer are needed to be changed.
Bir başkası bu kılavuzu tamamladı.
Jenish
169 İtibar
1 Kılavuz yazıldı
Bir Yorum
Those are hoses. Pipes are in the wall
NitWit - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 30
Son 30 gün: 186
Her zaman: 7,923
