Ana içeriğe geç
How to Replace KBD67 Lite R3 Keyboard Switch Spring
Neye ihtiyacın var
  1. How to Replace KBD67 Lite R3 Keyboard Switch Spring, Switch Spring: adım 1, 2 resimden 1. How to Replace KBD67 Lite R3 Keyboard Switch Spring, Switch Spring: adım 1, 2 resimden 2.
    • Align the keycap puller to the keycap.
    • Gently pull vertically on the keycap to remove it, exposing the key switch.
  2. How to Replace KBD67 Lite R3 Keyboard Switch Spring: adım 2, 3 resimden 1. How to Replace KBD67 Lite R3 Keyboard Switch Spring: adım 2, 3 resimden 2. How to Replace KBD67 Lite R3 Keyboard Switch Spring: adım 2, 3 resimden 3.
    • Align the key switch puller with the key switch that you're removing.
    • Pull the key switch out of the keyboard.
  3. How to Replace KBD67 Lite R3 Keyboard Switch Spring: adım 3, 3 resimden 1. How to Replace KBD67 Lite R3 Keyboard Switch Spring: adım 3, 3 resimden 2. How to Replace KBD67 Lite R3 Keyboard Switch Spring: adım 3, 3 resimden 3.
    • Locate the side of the switch that has latches.
    • Place the side of the switch with latches on top of the key switch opener legs.
    • Apply gentle force pushing the switch down on the switch opener to open up the switch.
  4. How to Replace KBD67 Lite R3 Keyboard Switch Spring: adım 4, 2 resimden 1. How to Replace KBD67 Lite R3 Keyboard Switch Spring: adım 4, 2 resimden 2.
    • Remove the top housing and stem to reveal the switch spring.
    • Remove the switch spring and proceed to replace it with another spring of your choice.
  5. How to Replace KBD67 Lite R3 Keyboard Switch Spring: adım 5, 3 resimden 1. How to Replace KBD67 Lite R3 Keyboard Switch Spring: adım 5, 3 resimden 2. How to Replace KBD67 Lite R3 Keyboard Switch Spring: adım 5, 3 resimden 3.
    • Locate the side of the switch that has legs, then place the switch on top of the spring. with the legs facing the metal plate.
    • Push the top and bottom housing together to assemble the switch.
    • Do not do this on the switch opener. The switch opener was used for photography purposes.
  6. How to Replace KBD67 Lite R3 Keyboard Switch Spring: adım 6, 3 resimden 1. How to Replace KBD67 Lite R3 Keyboard Switch Spring: adım 6, 3 resimden 2. How to Replace KBD67 Lite R3 Keyboard Switch Spring: adım 6, 3 resimden 3.
    • Locate the switch pin holes on your keyboard.
    • Locate the pins on your key switch and line it up with the keyboard pin holes.
    • Apply gentle force pushing down until it clicks onto place.
  7. How to Replace KBD67 Lite R3 Keyboard Switch Spring: adım 7, 1 resimden 1.
    • Put the key cap back onto the switch.
    • Test the keyboard input and ensure that everything is functioning correctly.
Sonuç
Frank Loi
145 İtibar
1 Kılavuz yazıldı
Ekip
1Rehber Yorum
Frank you did an amazing job on this one. I always wondered how to replace a keyboard key and finally you provided a perfect guide. Your introduction covers everything one needs to know including the parts required - thank you for the where to buy links. Talking about the guide it's clear and precise - all steps are documented well with those amazing parts focused pictures. Language is easy to read and understand. After reading your guide I feel more confident now to replace the key or the spring within.
Krushi Patel - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 50
Her zaman: 1,276
