Ana içeriğe geç
How to Replace Keys on a Keyboard
Neye ihtiyacın var
  1. How to Replace Keys on a Keyboard, Individual Keys: adım 1, 2 resimden 1. How to Replace Keys on a Keyboard, Individual Keys: adım 1, 2 resimden 2.
    • Loosen the key by prying all four corners gently with your spudger.
    • Make sure your keyboard is unplugged before performing any of these steps.
    FixBot'a Sor
    Yorum Ekle
  2. How to Replace Keys on a Keyboard: adım 2, 2 resimden 1. How to Replace Keys on a Keyboard: adım 2, 2 resimden 2.
    • Wedge the tip of the spudger under the bottom of the key and carefully lift up until the key pops loose.
    • If the key will not come out, or seems like too much force is needed, try step one again.
    FixBot'a Sor
    Yorum Ekle
  3. How to Replace Keys on a Keyboard: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use tweezers to remove any contaminants that were preventing the key from being pressed down from the now open hole on your keyboard.
    • Do not to grab the actual button, as breaking that could damage your keyboard permanently.
    FixBot'a Sor
    Yorum Ekle
  4. How to Replace Keys on a Keyboard: adım 4, 1 resimden 1.
    • Clean your keys with compressed air by blowing around the removed key.
    FixBot'a Sor
    Yorum Ekle
  5. How to Replace Keys on a Keyboard: adım 5, 2 resimden 1. How to Replace Keys on a Keyboard: adım 5, 2 resimden 2.
    • Push in the clean keys until you hear a popping sound.
    • The keys should click in easily, so if you are having trouble try realigning the key with its hole.
    • If you removed multiple keys, make sure they are in their proper spot and orientation.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Congratulations! You now have a keyboard with fully functional keys!
7 farklı kişi bu kılavuzu tamamladı.
Cooper
502 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-6, Green Winter 2015 Cal Poly, Team 24-6, Green Winter 2015 üyesi
CPSU-GREEN-W15S24G6
4 Üyeler
28 adet Kılavuz yazıldı
2Kılavuz Yorumları
This is How to CLEAN keys, not replace them. Duh.
Mike Miller - Yanıt Paylaş
I came looking for how to replace the problematic ones like + on numpad :<
Eskalina Cvrnkalikova - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 39
Son 30 gün: 186
Her zaman: 21,569
