Ana içeriğe geç
How to Replace Scott Mountain Bike Handlebars
Neye ihtiyacın var
  1. How to Replace Scott Mountain Bike Handlebars, Scott Mountain Bike Handlebars: adım 1, 2 resimden 1. How to Replace Scott Mountain Bike Handlebars, Scott Mountain Bike Handlebars: adım 1, 2 resimden 2.
    • Prop bike upright
    • Unscrew the hex bolts holding the front and rear shifter in place.
    • Use the H4 size hex wrench
    • Repeat for other side of handlebars.
  2. How to Replace Scott Mountain Bike Handlebars: adım 2, 1 resimden 1.
    • Slide the shifters toward the center of the handlebars so there is a gap between them and the grips.
  3. How to Replace Scott Mountain Bike Handlebars: adım 3, 1 resimden 1.
    • Use a flathead screwdriver to wedge a gap between the grip and the handlebars.
    • Twist grip around until it comes off of handlebar.
  4. How to Replace Scott Mountain Bike Handlebars: adım 4, 1 resimden 1.
    • Slide the shifters off of the end of the handlebars.
    • Let them hang on the bike.
  5. How to Replace Scott Mountain Bike Handlebars: adım 5, 1 resimden 1.
    • Unscrew the hex bolts holding the center bracket in place.
    • Use H3 hex wrench.
    • Place center bracket and hex screws off to the side. They will be needed in the next step.
  6. How to Replace Scott Mountain Bike Handlebars: adım 6, 1 resimden 1.
    • Attach new handlebars and screw the center bracket back in place.
    • Make sure that handlebars are centered.
  7. How to Replace Scott Mountain Bike Handlebars: adım 7, 1 resimden 1.
    • Slide the shifters back onto the handlebars so that the numbers are upright.
    • Do not screw them back in place yet.
  8. How to Replace Scott Mountain Bike Handlebars: adım 8, 1 resimden 1.
    • Slide the handlebar grips back onto the ends of the handlebars.
    • Slide the shifters back against the grips and screw them into place.
Sonuç
By following these steps, you will have your bike ready in no time.
Sean Slater
139 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 23-3, Green Winter 2015 Cal Poly, Team 23-3, Green Winter 2015 üyesi
CPSU-GREEN-W15S23G3
6 Üyeler
13 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 1,764
