Ana içeriğe geç
How to Replace Seat Fabric/Cushioning
Neye ihtiyacın var
  1. How to Replace Seat Fabric/Cushioning, Seat Fabric: adım 1, 2 resimden 1. How to Replace Seat Fabric/Cushioning, Seat Fabric: adım 1, 2 resimden 2.
    • Unscrew the seat from the chair frame using a screwdriver.
    • The type of screws securing the seat to the frame will vary from manufacturer to manufacturer; choose the appropriate screwdriver for your particular chair.
  2. How to Replace Seat Fabric/Cushioning: adım 2, 3 resimden 1. How to Replace Seat Fabric/Cushioning: adım 2, 3 resimden 2. How to Replace Seat Fabric/Cushioning: adım 2, 3 resimden 3.
    • Once the seat is separate from its base, flip it upside-down and remove the fabric staples with pliers.
    • Remove the fabric.
    • Optional: if you wish to replace the foam as well, place the seat base on top of the foam and trace around it with a marker. Use utility scissors to cut the foam.
  3. How to Replace Seat Fabric/Cushioning: adım 3, 1 resimden 1.
    • Place the foam or chair seat on top of your desired fabric.
    • Use a pair of scissors to cut the fabric, tracing around the foam or seat. Cut the fabric approximately 1.5 inches wider on the sides to allow it to wrap around the edges.
  4. How to Replace Seat Fabric/Cushioning: adım 4, 1 resimden 1.
    • Center the foam on the seat board, place the fabric on top of the foam, then flip the board over.
    • The fabric should be underneath and the board should be on the top.
    • Fold the fabric inward, toward the board.
    • Make sure the outside of the fabric is facing you as you fold it inward.
  5. How to Replace Seat Fabric/Cushioning: adım 5, 2 resimden 1. How to Replace Seat Fabric/Cushioning: adım 5, 2 resimden 2.
    • Staple the fabric to the seat, around the entire perimeter.
    • It helps to have a friend hold the fabric taut while you staple.
    • After everything is stapled, cut excess fabric (if necessary) using a pair of scissors.
  6. How to Replace Seat Fabric/Cushioning: adım 6, 2 resimden 1. How to Replace Seat Fabric/Cushioning: adım 6, 2 resimden 2.
    • Screw the refurbished seat back to the frame.
Sonuç
You're all set! Enjoy your brand-new looking chair!
3 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 22
Her zaman: 688
