Ana içeriğe geç
How to Replace T-fal Avante T24-B Toaster Lever
Neye ihtiyacın var
  1. How to Replace T-fal Avante T24-B Toaster Lever, T-fal Avante T24-B Toaster Lever: adım 1, 1 resimden 1.
    • Make sure the toaster is unplugged before beginning.
  2. How to Replace T-fal Avante T24-B Toaster Lever: adım 2, 3 resimden 1. How to Replace T-fal Avante T24-B Toaster Lever: adım 2, 3 resimden 2. How to Replace T-fal Avante T24-B Toaster Lever: adım 2, 3 resimden 3.
    • Remove the snap-on buttons from the front of the toaster.
    • They can be removed by pulling with your hands or gently prying with a flat tool.
  3. How to Replace T-fal Avante T24-B Toaster Lever: adım 3, 3 resimden 1. How to Replace T-fal Avante T24-B Toaster Lever: adım 3, 3 resimden 2. How to Replace T-fal Avante T24-B Toaster Lever: adım 3, 3 resimden 3.
    • Flip the toaster so that you can see its underside.
    • Remove the seven 20 mm Torx T3 screws from the bottom of the toaster.
  4. How to Replace T-fal Avante T24-B Toaster Lever: adım 4, 2 resimden 1. How to Replace T-fal Avante T24-B Toaster Lever: adım 4, 2 resimden 2.
    • Turn the toaster so that you can access the back of the toaster
    • Remove the 3 15 mm Torx T3 screws from the back of the toaster.
  5. How to Replace T-fal Avante T24-B Toaster Lever: adım 5, 2 resimden 1. How to Replace T-fal Avante T24-B Toaster Lever: adım 5, 2 resimden 2.
    • Pull off the toaster casing.
  6. How to Replace T-fal Avante T24-B Toaster Lever: adım 6, 2 resimden 1. How to Replace T-fal Avante T24-B Toaster Lever: adım 6, 2 resimden 2.
    • Unplug the casing so that it does not get in your way.
    • Unplug both wires connecting the casing to the internals of the toaster.
  7. How to Replace T-fal Avante T24-B Toaster Lever: adım 7, 3 resimden 1. How to Replace T-fal Avante T24-B Toaster Lever: adım 7, 3 resimden 2. How to Replace T-fal Avante T24-B Toaster Lever: adım 7, 3 resimden 3.
    • Pry both sides of the broken lever at the front of the toaster away and remove it.
  8. How to Replace T-fal Avante T24-B Toaster Lever: adım 8, 3 resimden 1. How to Replace T-fal Avante T24-B Toaster Lever: adım 8, 3 resimden 2. How to Replace T-fal Avante T24-B Toaster Lever: adım 8, 3 resimden 3.
    • Snap the replacement lever into place.
    • Attach one side first, then snap the other side on to fully attach the lever.
Sonuç
Cameron Johnson
157 İtibar
1 Kılavuz yazıldı
2Kılavuz Yorumları
Thank you so much!
S J - Yanıt
where do you get the replacement lever ?
Francois Rehel - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 34
Her zaman: 1,195
