Ana içeriğe geç
How to Replace Your iPhone 14 and 15 Rear Glass Adhesive
Neye ihtiyacın var
  1. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive, Remove the leftover adhesive: adım 1, 3 resimden 1. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive, Remove the leftover adhesive: adım 1, 3 resimden 2. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive, Remove the leftover adhesive: adım 1, 3 resimden 3.
    • The leftover adhesive on your frame resists peeling and leaves residue. If the adhesive feels stubborn, apply a low amount of heat using a hair dryer or heat gun.
    • Use either end of a spudger to press and roll the adhesive off the frame.
    • Use blunt nose tweezers or your fingers to remove loose pieces of adhesive.
  2. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive, Clean the rear glass: adım 2, 2 resimden 1. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive, Clean the rear glass: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    Microfiber Cleaning Cloths
    $3.99
    Satın Al
    • If you're reusing your back cover, apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to a microfiber or lint-free cloth and wipe around the perimeter to prepare the surface for new adhesive.
  3. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive, Clean the frame: adım 3, 2 resimden 1. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive, Clean the frame: adım 3, 2 resimden 2.
    • Any leftover residue will compromise your iPhone's seal. Be sure to clean the frame thoroughly.
    • Wrap a lint-free or microfiber cloth over the point of your spudger and apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to the cloth.
    • Wipe in one direction along the perimeter of the frame to clean the adhesive residue.
  4. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive, Orient the adhesive: adım 4, 2 resimden 1. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive, Orient the adhesive: adım 4, 2 resimden 2.
    • Orient your replacement adhesive over the frame with the larger blue liner on the underside and its pull tab in the bottom right corner.
    • Use features such as the camera cutout and notches along the top and bottom edges to visualize how the adhesive will lay in the frame.
  5. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive, Expose the adhesive: adım 5, 1 resimden 1.
    • Your replacement adhesive is very sticky. Don't let it touch anything until you're ready to apply it to the frame.
    • Use the blue liner pull tab to peel back and expose only the bottom edge of the adhesive.
  6. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive, Apply the adhesive: adım 6, 3 resimden 1. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive, Apply the adhesive: adım 6, 3 resimden 2. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive, Apply the adhesive: adım 6, 3 resimden 3.
    • Hold the blue liner out of the way and align the adhesive with the bottom edge of the iPhone.
    • Lay the bottom edge of the adhesive into its recess in the frame, making sure the iPhone's spring contacts are aligned with their cutouts in the liner.
  7. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive: adım 7, 2 resimden 1. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive: adım 7, 2 resimden 2.
    • Apply the adhesive up the sides of the iPhone, peeling the blue liner as you go.
    • If your adhesive isn't perfectly straight, pull the long edges into alignment with the frame.
  8. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive: adım 8, 3 resimden 1. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive: adım 8, 3 resimden 2. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive: adım 8, 3 resimden 3.
    • Double-check that the top edge notches are aligned with the frame.
    • Slowly lay the top edge of the adhesive onto the frame and roll the blue liner completely off.
  9. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive, Press the adhesive into place: adım 9, 3 resimden 1. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive, Press the adhesive into place: adım 9, 3 resimden 2. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive, Press the adhesive into place: adım 9, 3 resimden 3.
    • Use the flat end of your spudger to press the adhesive into place around the perimeter of the frame.
    • Be careful not to touch the spring contacts sticking through the pink liner.
  10. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive, Remove the adhesive liner: adım 10, 3 resimden 1. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive, Remove the adhesive liner: adım 10, 3 resimden 2. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive, Remove the adhesive liner: adım 10, 3 resimden 3.
    • Use the small pull tab in the top right corner to remove the pink adhesive liner.
  11. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive, Connect the charging coil: adım 11, 2 resimden 1. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive, Connect the charging coil: adım 11, 2 resimden 2.
    • Prop up the rear glass along the right edge of your iPhone.
  12. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive: adım 12, 2 resimden 1. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive: adım 12, 2 resimden 2.
    • Use the flat end of your spudger or your finger to reconnect the charging coil.
  13. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive: adım 13, 3 resimden 1. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive: adım 13, 3 resimden 2. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive: adım 13, 3 resimden 3.
    • Secure the charging coil connector cover using its slot or hook on the logic board.
    • Refer to your specific phone's replacement guide for detailed instructions on this part.
    • Use your tri-point Y000 driver to install the screw and secure the cover.
  14. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive, Connect the battery: adım 14, 3 resimden 1. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive, Connect the battery: adım 14, 3 resimden 2. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive, Connect the battery: adım 14, 3 resimden 3.
    • Use the flat end of your spudger or your finger to reconnect the battery.
    • Hook the battery connector cover onto its slot on the logic board.
    • Use your tri-point Y000 driver to install the screws and secure the cover.
    • Power on your iPhone and test it to make sure everything works before sealing it up. Power it back down before finishing this repair.
  15. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive, Remove the final adhesive liners: adım 15, 3 resimden 1. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive, Remove the final adhesive liners: adım 15, 3 resimden 2. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive, Remove the final adhesive liners: adım 15, 3 resimden 3.
    • Remove the liners from the top, left, and bottom edges of your iPhone. Wait to remove the liner along the right edge.
    • As you remove the liners, be sure nothing touches the exposed adhesive.
  16. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive: adım 16, 3 resimden 1. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive: adım 16, 3 resimden 2. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive: adım 16, 3 resimden 3.
    • Elevate the rear glass so you can access the final liner along the right edge of your iPhone.
    • Peel and remove the liner, making sure not to catch on any cables or clips on the rear glass.
  17. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive, Install the rear glass: adım 17, 3 resimden 1. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive, Install the rear glass: adım 17, 3 resimden 2. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive, Install the rear glass: adım 17, 3 resimden 3.
    • If any clips on the rear glass are bent, gently straighten them with your fingers.
    • Hold the rear glass and align it over the frame.
    • Lay the top edge of the rear glass straight down onto the frame until the top clips engage.
    • Press around the perimeter of the rear glass to engage the remaining clips.
  18. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive: adım 18, 3 resimden 1. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive: adım 18, 3 resimden 2. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive: adım 18, 3 resimden 3.
    • To help the adhesive bond, apply heat to the edges of the rear glass using an iOpener, hair dryer, or heat gun until it's hot to the touch.
    • Firmly press around the perimeter of the rear glass.
    • If you have screen vise clamps, use them to strengthen the bond of your new adhesive. If not, keep reading for more ways to secure the rear glass.
  19. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive, Secure the adhesive: adım 19, 3 resimden 1. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive, Secure the adhesive: adım 19, 3 resimden 2. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive, Secure the adhesive: adım 19, 3 resimden 3.
    • To evenly compress your iPhone and strengthen the bond of the rear glass to the frame, you need to account for the camera bump.
    • If you have the box your iPhone came in, take the lid and place it on a flat surface.
    • If you don't have your original box, skip this step for an alternate method.
    • Place your iPhone screen-side-up in the lid of your box with the camera bump in its recess.
    • Find something close to the size of your iPhone, but taller than the sides of the box. Stack it on top of the iPhone, followed by a few heavy objects.
    • Leave the objects in place for at least thirty minutes. The lighter the objects, the longer they should be left. Ideally, leave them stacked overnight.
  20. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive: adım 20, 2 resimden 1. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive: adım 20, 2 resimden 2.
    • If you don't have the original box for your iPhone, follow the next three steps for another method to evenly compress the rear glass.
    • Apply tape to the perimeter of your rear glass to protect its finish.
  21. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive: adım 21, 3 resimden 1. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive: adım 21, 3 resimden 2. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive: adım 21, 3 resimden 3.
    • Place two layers of coins or similarly thick objects on the tape along the edges of the rear glass.
    • Evenly distribute the coins and make sure they are as thick or thicker than the camera bump.
  22. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive: adım 22, 3 resimden 1. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive: adım 22, 3 resimden 2. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive: adım 22, 3 resimden 3.
    • Stack multiple books or other heavy objects on your iPhone.
    • The coins may leave an impression on the bottom book, so don't use anything valuable.
    • Leave the books in place for at least thirty minutes. The lighter the books, the longer they should be left. Ideally, leave them stacked overnight.
  23. How to Replace Your iPhone 14 and 15 Rear Glass Adhesive, Install the pentalobe screws: adım 23, 1 resimden 1.
    • Use your P2 pentalobe driver to install the two screws into the bottom edge of your iPhone.
Sonuç
Congratulations, your new adhesive is good to go!
3 farklı kişi bu kılavuzu tamamladı.
Clay Eickemeyer
65.905 İtibar
453 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
16.718 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 17
Son 7 gün: 170
Son 30 gün: 658
Her zaman: 4,770
