Ana içeriğe geç
How to Replace a Backpack Buckle (with sewing)
Neye ihtiyacın var
  1. How to Replace a Backpack Buckle (with sewing), Locate the repair area: adım 1, 2 resimden 1. How to Replace a Backpack Buckle (with sewing), Locate the repair area: adım 1, 2 resimden 2.
    • Identify where the broken buckle is and prepare the tools needed for the repair.
  2. How to Replace a Backpack Buckle (with sewing), Clean the area: adım 2, 3 resimden 1. How to Replace a Backpack Buckle (with sewing), Clean the area: adım 2, 3 resimden 2. How to Replace a Backpack Buckle (with sewing), Clean the area: adım 2, 3 resimden 3.
    • Use a seam ripper to unstitch the strap.
    • Remove the broken buckle and check that it is compatible with the replacement part.
    • Tip: The new buckle size must match the strap width.
  3. How to Replace a Backpack Buckle (with sewing), Test the replacement part: adım 3, 3 resimden 1. How to Replace a Backpack Buckle (with sewing), Test the replacement part: adım 3, 3 resimden 2. How to Replace a Backpack Buckle (with sewing), Test the replacement part: adım 3, 3 resimden 3.
    • Set the top part of the buckle aside (green circle).
    • Take the bottom part of the buckle (blue circle) and put it into the strap.
    • Hold it together with both hands and then insert it into the seam of the backpack.
  4. How to Replace a Backpack Buckle (with sewing), Stitch the bottom buckle in place: adım 4, 2 resimden 1. How to Replace a Backpack Buckle (with sewing), Stitch the bottom buckle in place: adım 4, 2 resimden 2.
    • Following the last step, keep holding together the strap with the bottom buckle with both hands and gently place it on the sewing machine.
    • Once the strap is set in place, start stitching the area.
    • Use a pair of scissors to cut any loose threads.
  5. How to Replace a Backpack Buckle (with sewing), Stitch the top buckle piece: adım 5, 3 resimden 1. How to Replace a Backpack Buckle (with sewing), Stitch the top buckle piece: adım 5, 3 resimden 2. How to Replace a Backpack Buckle (with sewing), Stitch the top buckle piece: adım 5, 3 resimden 3.
    • Repeat the previous steps to stitch the top buckle piece.
  6. How to Replace a Backpack Buckle (with sewing), Finished and ready!: adım 6, 3 resimden 1. How to Replace a Backpack Buckle (with sewing), Finished and ready!: adım 6, 3 resimden 2. How to Replace a Backpack Buckle (with sewing), Finished and ready!: adım 6, 3 resimden 3.
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
Sonuç
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
Ben Blischke
10.230 İtibar
66 adet Kılavuz yazıldı
Ekip
INTERSPORT INTERSPORT üyesi
Community
25 Üyeler
169 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 43
Her zaman: 458
