Ana içeriğe geç
How to Replace a Bicycle Bell Disc
Neye ihtiyacın var
  1. How to Replace a Bicycle Bell Disc, Disc Bell: adım 1, 2 resimden 1. How to Replace a Bicycle Bell Disc, Disc Bell: adım 1, 2 resimden 2.
    • Unscrew the exterior bell housing by rotating clockwise, then remove the housing.
  2. How to Replace a Bicycle Bell Disc: adım 2, 2 resimden 1. How to Replace a Bicycle Bell Disc: adım 2, 2 resimden 2.
    • Rotate the parallel bars clockwise until they separate from the rod they're mounted on.
  3. How to Replace a Bicycle Bell Disc: adım 3, 2 resimden 1. How to Replace a Bicycle Bell Disc: adım 3, 2 resimden 2.
    • Remove the rubber discs.
    • Grab your new rubber discs and insert one at each end of the parallel bars.
    • Make sure center of the rubber discs are held in place by the pins.
  4. How to Replace a Bicycle Bell Disc: adım 4, 1 resimden 1.
    • Test and rotate the discs with your finger to see if it is the appropriate size.
    • If the disc does not rotate easily, change the size of your metal disc to a narrower one.
  5. How to Replace a Bicycle Bell Disc: adım 5, 2 resimden 1. How to Replace a Bicycle Bell Disc: adım 5, 2 resimden 2.
    • Rotate the parallel bars counterclockwise, into their original position.
  6. How to Replace a Bicycle Bell Disc: adım 6, 2 resimden 1. How to Replace a Bicycle Bell Disc: adım 6, 2 resimden 2.
    • Replace the exterior housing and rotate it counterclockwise until it's fully secure.
Sonuç
Your bell should now be ringing like new!
Susan
133 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 19
Son 30 gün: 100
Her zaman: 1,335
