Ana içeriğe geç
How to Replace a Bicycle Guide Pulley
Neye ihtiyacın var
  1. How to Replace a Bicycle Guide Pulley, Bicycle Guide Pulley: adım 1, 1 resimden 1.
    • Set your bike upside down by letting it stand on its handlebars and seat.
  2. How to Replace a Bicycle Guide Pulley: adım 2, 3 resimden 1. How to Replace a Bicycle Guide Pulley: adım 2, 3 resimden 2. How to Replace a Bicycle Guide Pulley: adım 2, 3 resimden 3.
    • If the pulley is still in place, unscrew it from the arm with the allen wrench.
    • Using the towel with the alcohol or degreaser, clean the pulley and check for cracks or broken teeth.
    • If any extensive damage is present, discard the pulley.
    • Be sure to clean and check the pulley's condition if it has fallen out of the arm.
  3. How to Replace a Bicycle Guide Pulley: adım 3, 2 resimden 1. How to Replace a Bicycle Guide Pulley: adım 3, 2 resimden 2.
    • The replacement pulley should come with a bearing. Remove the bearing.
    • Grease the pulley and bearing thoroughly.
  4. How to Replace a Bicycle Guide Pulley: adım 4, 2 resimden 1. How to Replace a Bicycle Guide Pulley: adım 4, 2 resimden 2.
    • Push the bearing back into the pulley.
  5. How to Replace a Bicycle Guide Pulley: adım 5, 3 resimden 1. How to Replace a Bicycle Guide Pulley: adım 5, 3 resimden 2. How to Replace a Bicycle Guide Pulley: adım 5, 3 resimden 3.
    • Place the teeth of the pulley against the chain, then push it with the chain into the derailleur arm.
  6. How to Replace a Bicycle Guide Pulley: adım 6, 2 resimden 1. How to Replace a Bicycle Guide Pulley: adım 6, 2 resimden 2.
    • Grease the screw that holds the pulley in place.
    • Screw the pulley back into the derailleur with the allen wrench.
  7. How to Replace a Bicycle Guide Pulley: adım 7, 1 resimden 1.
    • While temporarily lifting the chain off the pulley, check to see if the pulley rotates freely.
  8. How to Replace a Bicycle Guide Pulley: adım 8, 1 resimden 1.
    • Push on the pedals to see if the derailleur is back in working order.
Sonuç
To remove your pulley, see Step 2.
Kayla Bru
128 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 10-6, Green Fall 2015 Cal Poly, Team 10-6, Green Fall 2015 üyesi
CPSU-GREEN-F15S10G6
3 Üyeler
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 19
Her zaman: 1,564
