Giriş
Bottom bracket broken and can't ride your bike? This guide will walk you through how to remove the bottom bracket, how to grease the threads of the new bottom bracket, and then how to reinstall the bottom bracket. This instruction manual is specific to square taper bottom brackets.
Neye ihtiyacın var
Insert the bottom bracket tool into the bottom bracket. Use the tool to turn the bottom bracket counter clock wise. It will be difficult to turn, but enough force will get it to turn.
Completely remove the small side of the bottom bracket.
Repeat for the side with the drive train, except turn the bottom bracket tool clockwise this time.
Use the bottom bracket tool to screw in the larger side (drive side) of the bottom bracket. Make sure to screw it in counter clock wise.
Screw the bottom bracket in all the way, but make sure not to tighten it down.
Repeat for the smaller side, except screw the bottom bracket in clock wise.
Tighten both sides down with the bottom bracket tool.
Congratulations! You are finished and can ride your bike again!
13 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Some people just like the feel of holding the catalog, newspaper Free Catalog or magazine in their hands.
