Ana içeriğe geç
How to Replace a Broken Window Wand Tilt Mechanism
  1. How to Replace a Broken Window Wand Tilt Mechanism, Wand Tilt Mechanism: adım 1, 3 resimden 1. How to Replace a Broken Window Wand Tilt Mechanism, Wand Tilt Mechanism: adım 1, 3 resimden 2. How to Replace a Broken Window Wand Tilt Mechanism, Wand Tilt Mechanism: adım 1, 3 resimden 3.
    • Lift up the wand sleeve with your fingers to clear access for the wand to slide out.
    • Once the sleeve is pushed up, rotate the wand horizontally to unhook it from the tilt mechanism.
  2. How to Replace a Broken Window Wand Tilt Mechanism: adım 2, 2 resimden 1. How to Replace a Broken Window Wand Tilt Mechanism: adım 2, 2 resimden 2.
    • Lift the header board off the window shade by gently prying up and away from the window blind.
  3. How to Replace a Broken Window Wand Tilt Mechanism: adım 3, 3 resimden 1. How to Replace a Broken Window Wand Tilt Mechanism: adım 3, 3 resimden 2. How to Replace a Broken Window Wand Tilt Mechanism: adım 3, 3 resimden 3.
    • Unhook the end clips on the window blind by pulling with your fingers toward yourself in an upward motion.
  4. How to Replace a Broken Window Wand Tilt Mechanism: adım 4, 2 resimden 1. How to Replace a Broken Window Wand Tilt Mechanism: adım 4, 2 resimden 2.
    • Remove the window blind by pulling it away from the brackets.
  5. How to Replace a Broken Window Wand Tilt Mechanism: adım 5, 3 resimden 1. How to Replace a Broken Window Wand Tilt Mechanism: adım 5, 3 resimden 2. How to Replace a Broken Window Wand Tilt Mechanism: adım 5, 3 resimden 3.
    • Slide the end cap off the header to allow for more access.
    • Lift the center rod in an upward motion to unlock it from the header.
  6. How to Replace a Broken Window Wand Tilt Mechanism: adım 6, 3 resimden 1. How to Replace a Broken Window Wand Tilt Mechanism: adım 6, 3 resimden 2. How to Replace a Broken Window Wand Tilt Mechanism: adım 6, 3 resimden 3.
    • Remove the tilt wand mechanism by sliding it off the center rod.
  7. How to Replace a Broken Window Wand Tilt Mechanism: adım 7, 3 resimden 1. How to Replace a Broken Window Wand Tilt Mechanism: adım 7, 3 resimden 2. How to Replace a Broken Window Wand Tilt Mechanism: adım 7, 3 resimden 3.
    • Install the new tilt wand mechanism by sliding it on the center rod.
    • Once slid into position, reinsert the center rod by pushing down on the assembly.
  8. How to Replace a Broken Window Wand Tilt Mechanism: adım 8, 1 resimden 1.
    • Visually inspect alignment, fitment, and proper function of the newly installed tilt wand mechanism.
    • Insure the clip is securely held in place.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 24
Son 7 gün: 129
Son 30 gün: 537
Her zaman: 18,055
