Ana içeriğe geç
How to Replace a Cabinet Door
Neye ihtiyacın var
  1. How to Replace a Cabinet Door, Cabinet Door: adım 1, 1 resimden 1.
    • Using a screwdriver, either a Flathead or a Phillips, remove the screws starting from the bottom of the door all the way to the top of the door to prevent the door from swinging.
  2. How to Replace a Cabinet Door: adım 2, 1 resimden 1.
    • Next using a screwdriver, remove the screws attaching the hinge to the door.
  3. How to Replace a Cabinet Door: adım 3, 3 resimden 1. How to Replace a Cabinet Door: adım 3, 3 resimden 2. How to Replace a Cabinet Door: adım 3, 3 resimden 3.
    • Place the new cabinet on a flat surface. Then line up the old (or new) hinge's to holes on the door.
  4. How to Replace a Cabinet Door: adım 4, 3 resimden 1. How to Replace a Cabinet Door: adım 4, 3 resimden 2. How to Replace a Cabinet Door: adım 4, 3 resimden 3.
    • Finally, line up the hinge’s holes with the holes from the previous cabinet door. Then screw the new door on.
Sonuç
To reassemble your cabinet, follow these instructions in reverse order.
Bir başkası bu kılavuzu tamamladı.
Kayleah Cumpian
151 İtibar
1 Kılavuz yazıldı
Ekip
Texas Tech, Team 22-7, Rauch Spring 2016 Texas Tech, Team 22-7, Rauch Spring 2016 üyesi
TTU-RAUCH-S16S22G7
3 Üyeler
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 14
Son 30 gün: 48
Her zaman: 1,685
