Ana içeriğe geç
How to Replace a Cat5e Wall Jack
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
  1. How to Replace a Cat5e Wall Jack, Cat5e Wall Jack: adım 1, 1 resimden 1.
    • Remove the faceplate from the wall using either a phillips or flathead screwdriver.
  2. How to Replace a Cat5e Wall Jack: adım 2, 1 resimden 1.
    • Once removed, un-clip the keystone jack from the wall plate by depressing the tab back side of the wall plate.
  3. How to Replace a Cat5e Wall Jack: adım 3, 1 resimden 1.
    • Inspect the wiring and make note of the order of the wire locations.
  4. How to Replace a Cat5e Wall Jack: adım 4, 1 resimden 1.
    • Remove the wires from the old jack by gently pulling them out of their connector slots.
  5. How to Replace a Cat5e Wall Jack: adım 5, 1 resimden 1.
    • Trim the tips of the wires at the point where they were originally connected to help assure a good connection to the new jack.
  6. How to Replace a Cat5e Wall Jack: adım 6, 1 resimden 1.
    • Separate the wires into the appropriate pairs and twist them together until about one half inch from the ends.
  7. How to Replace a Cat5e Wall Jack: adım 7, 1 resimden 1.
    • Using the plastic punchdown tool, (typically supplied with a new jack), press the prepared wires into their appropriate locations on the replacement jack.
  8. How to Replace a Cat5e Wall Jack: adım 8, 1 resimden 1.
    • Once all wires have been properly installed test the Ethernet connectivity with a known good Cat 5E cable and a working device, such as a laptop computer.
  9. How to Replace a Cat5e Wall Jack: adım 9, 1 resimden 1.
    • After a good connection has been determined to exist, snap the new jack into the faceplate.
  10. How to Replace a Cat5e Wall Jack: adım 10, 1 resimden 1.
    • Carefully insert the Cat5E wiring back into the wall and screw the face plate onto the wall.
  11. How to Replace a Cat5e Wall Jack: adım 11, 1 resimden 1.
    • Hook up your Ethernet device and you are now ready to surf the web.
Sonuç
If you're having trouble you can try the following troubleshooting steps: (1)Try using a different device in case your test device is having trouble, if the device is sound, (2) then try using a different Ethernet cable, finally, if the cable is good (3) make sure you didn't knock any wires out of place when you screwed the jack back in place. If everything works as it should, you have successfully replaced the Cat5e wall jack.
7 farklı kişi bu kılavuzu tamamladı.
DelVonte Deary
207 İtibar
1 Kılavuz yazıldı
Ekip
Colorado Springs, Team 1-5, Mcmichael SU 2015 Colorado Springs, Team 1-5, Mcmichael SU 2015 üyesi
UCCS-MCMICHAEL-SU15S1G5
3 Üyeler
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,719
