Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
How to Replace a Coffee Tabletop Glass
  1. How to Replace a Coffee Tabletop Glass, Glass: adım 1, 2 resimden 1. How to Replace a Coffee Tabletop Glass, Glass: adım 1, 2 resimden 2.
    • Flip the coffee table base upside down on an empty area.
  2. How to Replace a Coffee Tabletop Glass: adım 2, 1 resimden 1.
    • Use a cleaning spray to clean the surface of the glass table.
    • Use gloves while cleaning the table. The glass cleaner spray may contain toxic chemicals.
  3. How to Replace a Coffee Tabletop Glass: adım 3, 2 resimden 1. How to Replace a Coffee Tabletop Glass: adım 3, 2 resimden 2.
    • Use a Phillips #2 screwdriver to remove one 1/4 in.-20 x 1-1/2 in. socket cap screw from the side of the glass.
    • Repeat the process for the other 1/4 in.-20 x 1-1/2 in. socket cap screw.
    • The appearance of this screw may differ from table to table, but the procedure remains the same. Use the appropriate screwdriver to open the screws.
  4. How to Replace a Coffee Tabletop Glass: adım 4, 2 resimden 1. How to Replace a Coffee Tabletop Glass: adım 4, 2 resimden 2.
    • Remove the coffee table legs piece by piece.
  5. How to Replace a Coffee Tabletop Glass: adım 5, 1 resimden 1.
    • Remove the glass.
    • Remember that glass can be shattered or partially damaged. Use gloves to avoid possible cuts.
  6. How to Replace a Coffee Tabletop Glass: adım 6, 1 resimden 1.
    • Replace the broken/ damaged glass with the new one.
Sonuç
Jasrin Kaur
133 İtibar
1 Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 55
Son 30 gün: 201
Her zaman: 1,414
