Ana içeriğe geç
How to Replace a Corroded Car Battery Terminal
Neye ihtiyacın var
    1. How to Replace a Corroded Car Battery Terminal, Car Battery Terminal: adım 1, 2 resimden 1. How to Replace a Corroded Car Battery Terminal, Car Battery Terminal: adım 1, 2 resimden 2.
      • Remember to remove your car key from the ignition and shut off the car before performing this guide.
      • Locate the terminals on the top of the car battery. Next to each terminal is a positive(+) or negative(-) sign, indicating the charge.
      • The positive terminal looks to be in working order, but the negative end has a lot of corrosion buildup. This terminal needs to be replaced.
      FixBot'a Sor
      Yorum Ekle
    2. How to Replace a Corroded Car Battery Terminal: adım 2, 2 resimden 1. How to Replace a Corroded Car Battery Terminal: adım 2, 2 resimden 2.
      • Find the nut located on the side of the terminal.
      • Using an adjustable wrench, rotate the nut counterclockwise to loosen it.
      • Use an appropriately-sized wrench or socket, not channel locks as shown in the photo.
      • You do not need to loosen the nut all the way off the bolt, but just enough to loosen the terminal's grip on the node.
      FixBot'a Sor
      Yorum Ekle
    3. How to Replace a Corroded Car Battery Terminal: adım 3, 2 resimden 1. How to Replace a Corroded Car Battery Terminal: adım 3, 2 resimden 2.
      • Always remember to remove the negative terminal first before the positive terminal. This will prevent shorting to the ground and possibly causing shock or a fire.
      • Carefully use a rag to lift up the terminal off of the battery node.
      • Be cautious when handling battery corrosion, as it can irritate the skin and is harmful if it comes in contact with your eyes.
      • Place the terminal on a rag or towel and make sure it doesn't come in contact with the battery node.
      FixBot'a Sor
      Yorum Ekle
    4. How to Replace a Corroded Car Battery Terminal: adım 4, 2 resimden 1. How to Replace a Corroded Car Battery Terminal: adım 4, 2 resimden 2.
      • On the positive terminal, locate the nut along the side.
      • Using the wrench, rotate the nut counterclockwise.
      • You do not need to fully loosen the nut off the bolt, but just enough for the terminal to be easily removed from the node.
      FixBot'a Sor
      Yorum Ekle
    5. How to Replace a Corroded Car Battery Terminal: adım 5, 2 resimden 1. How to Replace a Corroded Car Battery Terminal: adım 5, 2 resimden 2.
      • Using a rag, carefully remove the positive terminal from the battery node.
      • Place the terminal on a rag or towel, and make sure it does not come into contact with the battery node.
      FixBot'a Sor
      Yorum Ekle
    6. How to Replace a Corroded Car Battery Terminal: adım 6, 3 resimden 1. How to Replace a Corroded Car Battery Terminal: adım 6, 3 resimden 2. How to Replace a Corroded Car Battery Terminal: adım 6, 3 resimden 3.
      • On the negative terminal, locate the nut on the side facing upwards.
      • Using the wrench, rotate the nut counterclockwise and remove it from the bolt.
      FixBot'a Sor
      Yorum Ekle
    7. How to Replace a Corroded Car Battery Terminal: adım 7, 3 resimden 1. How to Replace a Corroded Car Battery Terminal: adım 7, 3 resimden 2. How to Replace a Corroded Car Battery Terminal: adım 7, 3 resimden 3.
      • Take the wire plate on top and remove it carefully from the bolt.
      • At this point, it is fine to handle the metal plate with your hands since the terminals are disconnected from the battery and there is nothing completing the circuit.
      • Remove the bottom wire plate from the bolt, placing it carefully to the side.
      FixBot'a Sor
      Yorum Ekle
    8. How to Replace a Corroded Car Battery Terminal: adım 8, 2 resimden 1. How to Replace a Corroded Car Battery Terminal: adım 8, 2 resimden 2.
      • Set aside the old battery terminal, and replace it with the new one.
      • Replace the wire plates in the order they were taken off.
      • Although it is not necessary that the plates be placed in the same order again, it is generally a good idea to go with the order that it came in.
      FixBot'a Sor
      Yorum Ekle
    9. How to Replace a Corroded Car Battery Terminal: adım 9, 2 resimden 1. How to Replace a Corroded Car Battery Terminal: adım 9, 2 resimden 2.
      • Place the flat washer and the screw-on head that came with the battery terminal onto the vertical bolt.
      • Tighten the head clockwise and make sure the wire plates are secured.
      • Not all battery terminal packs come with a washer and screw-on head. If your pack comes with a nut, use the wrench and tighten the bolt clockwise.
      FixBot'a Sor
      Yorum Ekle
    10. How to Replace a Corroded Car Battery Terminal: adım 10, 1 resimden 1.
      • Using a rag, place the positive terminal back onto the positive node.
      FixBot'a Sor
      Yorum Ekle
    11. How to Replace a Corroded Car Battery Terminal: adım 11, 1 resimden 1.
      • Place the negative terminal back onto the negative node.
      FixBot'a Sor
      Yorum Ekle
    12. How to Replace a Corroded Car Battery Terminal: adım 12, 3 resimden 1. How to Replace a Corroded Car Battery Terminal: adım 12, 3 resimden 2. How to Replace a Corroded Car Battery Terminal: adım 12, 3 resimden 3.
      • On the negative terminal, use the wrench to rotate the side nut clockwise to tighten it.
      • Next, perform the same action on the side nut of the positive terminal.
      • To ensure a secure connection, be sure the nut is snug and that the terminal can't come off easily.
      FixBot'a Sor
      Yorum Ekle
Bitiş Çizgisi
22 farklı kişi bu kılavuzu tamamladı.
David Wright
775 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 12-4, Green Winter 2015 Cal Poly, Team 12-4, Green Winter 2015 üyesi
CPSU-GREEN-W15S12G4
5 Üyeler
45 adet Kılavuz yazıldı
8Kılavuz Yorumları
Nice post. Shop car battery at batterybhai and their expert technical team come to install the battery with all battery replacement tools kit.
mayank tanwar - Yanıt Paylaş
very interesting post. Thanks for sharing it.
https://www.sarexports.com/product-categ...
Raman Malik - Yanıt Paylaş
I change negative terminal to new one still have corrosion why?
אנדריי מזילו - Yanıt Paylaş
They are corrotion after doinging this within a4 to 5 month time the red cable is worst
Carol - Yanıt Paylaş
Use Petroleum-Jelly (preferably) OR if not there then
use Vaseline onto both the Terminals( +, -ive) to prevent rusting of your both terminals of Battery PLEASE .
SANJAY KHANDELWAL - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 20
Son 7 gün: 188
Son 30 gün: 737
Her zaman: 150,147
