Ana içeriğe geç
How to Replace a Curtain Rod
Neye ihtiyacın var
  1. How to Replace a Curtain Rod, Curtain Rod: adım 1, 2 resimden 1. How to Replace a Curtain Rod, Curtain Rod: adım 1, 2 resimden 2.
    • Remove the rod off the hook from the wall carefully with your hands.
  2. How to Replace a Curtain Rod: adım 2, 3 resimden 1. How to Replace a Curtain Rod: adım 2, 3 resimden 2. How to Replace a Curtain Rod: adım 2, 3 resimden 3.
    • Remove the screws from the hooks using a Phillips screwdriver or power drill with a Phillips head.
  3. How to Replace a Curtain Rod: adım 3, 2 resimden 1. How to Replace a Curtain Rod: adım 3, 2 resimden 2.
    • Use the tape measure to determine screw placement on the wall for the new curtain rod.
  4. How to Replace a Curtain Rod: adım 4, 2 resimden 1. How to Replace a Curtain Rod: adım 4, 2 resimden 2.
    • Replace the Phillips head in the power drill with a drill bit.
    • Drill the holes into the wall for the screws to secure firmly.
  5. How to Replace a Curtain Rod: adım 5, 1 resimden 1.
    • Place the screw into the hole on the hook and drill it into the holes on the wall.
  6. How to Replace a Curtain Rod: adım 6, 2 resimden 1. How to Replace a Curtain Rod: adım 6, 2 resimden 2.
    • Measure an equal distance between each hook. Repeat Step 5 for drilling in each hook on the wall.
  7. How to Replace a Curtain Rod: adım 7, 2 resimden 1. How to Replace a Curtain Rod: adım 7, 2 resimden 2.
    • Insert the rod into the curtain hole, leaving at least two inches of the rod on each side uncovered for hook placement.
  8. How to Replace a Curtain Rod: adım 8, 2 resimden 1. How to Replace a Curtain Rod: adım 8, 2 resimden 2.
    • Place the rod onto the curve of the hook for attachment. Then straighten out the curtain across the window.
Bitiş Çizgisi
Andrew Pfeiffer
157 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 17
Her zaman: 1,525
