Ana içeriğe geç
How to Replace a Damaged Gutter Segment
Neye ihtiyacın var
  1. How to Replace a Damaged Gutter Segment, Eavestrough Gutter Segment: adım 1, 1 resimden 1.
    • Identify the section of the gutter system that needs to be replaced, specifically the middle gutter.
  2. How to Replace a Damaged Gutter Segment: adım 2, 2 resimden 1. How to Replace a Damaged Gutter Segment: adım 2, 2 resimden 2.
    • Using a screwdriver, remove the screws from the strip that holds the gutter to the wall.
    • Repeat this process for each strip along the length of the gutter.
    • Spread apart the strips to release the gutter.
    • When spreading apart the strips, they may have sharp edges. To ensure your safety, please use caution and wear protective gloves.
  3. How to Replace a Damaged Gutter Segment: adım 3, 3 resimden 1. How to Replace a Damaged Gutter Segment: adım 3, 3 resimden 2. How to Replace a Damaged Gutter Segment: adım 3, 3 resimden 3.
    • Locate the connecting points between the bottom gutter and the middle gutter.
    • Using a screwdriver, remove the screws.
    • Separate the bottom gutter from the middle gutter by sliding them apart.
  4. How to Replace a Damaged Gutter Segment: adım 4, 3 resimden 1. How to Replace a Damaged Gutter Segment: adım 4, 3 resimden 2. How to Replace a Damaged Gutter Segment: adım 4, 3 resimden 3.
    • Detach the top gutter from the connected fittings.
    • Position yourself securely on a ladder or elevated platform at the appropriate height to access the top gutter.
    • Place the removed top gutter and the middle gutter on the ground.
    • Inspect both the top gutter and the middle gutter for any damage. Assess whether they need to be entirely replaced or if repairs can be made.
    • If the damaged area is serious, you can only replace with a new segment (looking for environmentally friendly materials to protect the earth).
  5. How to Replace a Damaged Gutter Segment: adım 5, 3 resimden 1. How to Replace a Damaged Gutter Segment: adım 5, 3 resimden 2. How to Replace a Damaged Gutter Segment: adım 5, 3 resimden 3.
    • Slide the new middle gutter into the top gutter, inserting it gently until they are firmly connected.
    • Double-check that the alignment is correct and there are no gaps between the sections to avoid any drainage.
    • With the middle and top gutters connected, reattach the assembled gutters to the connected fittings.
  6. How to Replace a Damaged Gutter Segment: adım 6, 3 resimden 1. How to Replace a Damaged Gutter Segment: adım 6, 3 resimden 2. How to Replace a Damaged Gutter Segment: adım 6, 3 resimden 3.
    • Load a screw into the strip, positioning it so that it can be screwed into the holes of both the strip and the gutter.
    • Fold the strip around the gutter, aligning the holes of the strip with the corresponding holes on the gutter.
    • Screw the screws into the holes of the strip and the gutter, using a screwdriver.
    • Repeat this process for each strip along the length of the new middle gutter.
    • Take care not to overtighten the screw, as it may damage the gutter or strip the threads.
  7. How to Replace a Damaged Gutter Segment: adım 7, 3 resimden 1. How to Replace a Damaged Gutter Segment: adım 7, 3 resimden 2. How to Replace a Damaged Gutter Segment: adım 7, 3 resimden 3.
    • Position the bottom gutter in its intended location, ensuring that the holes on both pieces line up properly.
    • Using a screwdriver, tighten the screws to fasten the middle and bottom gutters together.
    • Replacement Complete!
Bitiş Çizgisi
Gavin Luc
145 İtibar
1 Kılavuz yazıldı
Ekip
York University, Team D-74, O'Regan Fall 2023 York University, Team D-74, O'Regan Fall 2023 üyesi
YORK-O'REGAN-F23SDG74
1 Üye
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 76
Her zaman: 794
