Ana içeriğe geç
How to Replace a Jacket Pocket
Neye ihtiyacın var
  1. How to Replace a Jacket Pocket, Pocket: adım 1, 2 resimden 1. How to Replace a Jacket Pocket, Pocket: adım 1, 2 resimden 2.
    • Use the seam cutter to cut and remove the seams attaching the pocket to the jacket.
    • Make sure to cut the seams away from you to ensure that you don't end up stabbing yourself with the seam cutter.
  2. How to Replace a Jacket Pocket: adım 2, 2 resimden 1. How to Replace a Jacket Pocket: adım 2, 2 resimden 2.
    • Measure the pocket length and width using measuring tape and a measuring board.
  3. How to Replace a Jacket Pocket: adım 3, 2 resimden 1. How to Replace a Jacket Pocket: adım 3, 2 resimden 2.
    • Trace the pocket to create a sewing pattern on a piece of paper with a pen.
    • Draw out the length and width of the pocket to the side as a reference for its size.
  4. How to Replace a Jacket Pocket: adım 4, 2 resimden 1. How to Replace a Jacket Pocket: adım 4, 2 resimden 2.
    • Cut out the sewing pattern from the paper using scissors.
    • Leave an extra inch where the pocket opening should be when cutting out the pattern.
  5. How to Replace a Jacket Pocket: adım 5, 2 resimden 1. How to Replace a Jacket Pocket: adım 5, 2 resimden 2.
    • Pin the sewing pattern to the Fat Quarter 100% cotton fabric.
    • Leave a boarder of fabric around the sewing pattern to help make precise cuts.
  6. How to Replace a Jacket Pocket: adım 6, 2 resimden 1. How to Replace a Jacket Pocket: adım 6, 2 resimden 2.
    • Use sewing scissors to cut the fabric along the pattern. These pieces will be sewn together to form the pocket.
    • Repeat the process for the other side of the pocket.
  7. How to Replace a Jacket Pocket: adım 7, 2 resimden 1. How to Replace a Jacket Pocket: adım 7, 2 resimden 2.
    • Pin both fabrics together with their sides aligned exactly in the same direction as the sewing pattern.
    • Make sure that both sides where the pocket opening should be are aligned.
    • Use the sewing pattern as a reference for where the fabric should be laid out and pinned together.
  8. How to Replace a Jacket Pocket: adım 8, 2 resimden 1. How to Replace a Jacket Pocket: adım 8, 2 resimden 2.
    • Sew the fabric together with the Singer Stitch Sew Quick to form the pocket with a 10mm margin of space from the raw cut edges of the fabric.
    • Leave only the pocket opening unstitched by stopping a few centimeters before it, helping to create the pocket fold.
    • Use the pocket that you cut out of the jacket as a reference point for what the stitching should look like.
    • Any standard sewing machine can be used as an alternative to the Singer Stitch Sew Quick device. Another option is hand sewing.
  9. How to Replace a Jacket Pocket: adım 9, 2 resimden 1. How to Replace a Jacket Pocket: adım 9, 2 resimden 2.
    • Use scissors to cutting off any loose thread.
  10. How to Replace a Jacket Pocket: adım 10, 3 resimden 1. How to Replace a Jacket Pocket: adım 10, 3 resimden 2. How to Replace a Jacket Pocket: adım 10, 3 resimden 3.
    • Iron out the new pocket with the steam iron.
    • Make sure to place the iron in an upright position when not in use. Pay attention to the fabric you are ironing to avoid burning, and don't touch the face of the iron as it will burn you.
  11. How to Replace a Jacket Pocket: adım 11, 2 resimden 1. How to Replace a Jacket Pocket: adım 11, 2 resimden 2.
    • Insert the new pocket into the jacket.
    • The pocket opening should face the outside, where the previous pocket was ripped out.
    • The stitching and needlework of the pocket should face the outside, leaving the inside of the pocket clean without any noticeable threads when used.
  12. How to Replace a Jacket Pocket: adım 12, 3 resimden 1. How to Replace a Jacket Pocket: adım 12, 3 resimden 2. How to Replace a Jacket Pocket: adım 12, 3 resimden 3.
    • Pin the new pocket to the jacket.
    • Flip back the pocket opening flaps to create a fold for the pocket opening and conceal the raw cut edges.
  13. How to Replace a Jacket Pocket: adım 13, 3 resimden 1. How to Replace a Jacket Pocket: adım 13, 3 resimden 2. How to Replace a Jacket Pocket: adım 13, 3 resimden 3.
    • Stitch the new pocket onto the jacket using a leather needle and polyester thread.
    • Use a thimble to help push the needle through the fabric and leather.
    • Be careful when the needle is interweaving between the fabrics, as the needle can prick you, causing bleeding.
Bitiş Çizgisi
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 27
Son 30 gün: 157
Her zaman: 1,836
