Ana içeriğe geç
How to Replace a Jeans Zipper with Buttons
Neye ihtiyacın var
  1. How to Replace a Jeans Zipper with Buttons, Zipper: adım 1, 3 resimden 1. How to Replace a Jeans Zipper with Buttons, Zipper: adım 1, 3 resimden 2. How to Replace a Jeans Zipper with Buttons, Zipper: adım 1, 3 resimden 3.
    • Open the broken zipper and identify the stitches.
    • Take the seam ripper and insert it under the last stitch seen.
    • Remove the stitches of the zipper and when most are removed, cut the rest of the zipper with fabric scissors.
    • Make sure to remove at least one half of the zipper.
  2. How to Replace a Jeans Zipper with Buttons: adım 2, 2 resimden 1. How to Replace a Jeans Zipper with Buttons: adım 2, 2 resimden 2.
    • Insert the buttons tack to the right fly of the jeans.
    • Insert 2 or 3 button tacks, depending on the length of the fly.
    • Add textile glue to the pointed part of the tacks.
    • Adding glue to the tacks helps secure the buttons and avoids damage caused by the washing machine and daily use.
  3. How to Replace a Jeans Zipper with Buttons: adım 3, 1 resimden 1.
    • While the textile glue is fresh, insert the buttons into the tacks and make sure they are secure.
    • You will notice the buttons are secure after you hear a clicking noise when pressing the buttons to the tacks.
  4. How to Replace a Jeans Zipper with Buttons: adım 4, 1 resimden 1.
    • Cut three holes using the pointed part of the fabric scissor on the left fly of the jeans that correspond with the buttons on the right.
    • Make sure to open the fabric scissor and use only one blade.
    • Alternatively if you have access to a sewing machine, follow this guide to create the button holes.
  5. How to Replace a Jeans Zipper with Buttons: adım 5, 1 resimden 1.
    • Using a needle and some thread, stitch the edges of the button holes to finish them.
  6. How to Replace a Jeans Zipper with Buttons: adım 6, 1 resimden 1.
    • Make sure the buttons are secure, that they fit the holes, and that they open and close easily.
Sonuç
At the end of the guide, you will have a pair of jeans that close with a set of buttons instead of a zipper.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 19
Son 30 gün: 79
Her zaman: 3,602
