Giriş
Have you ever put on a pair of jeans and when you try to zip them up it breaks? Broken zippers are a common struggle that most people suffer daily because of the quality of the product or just because of the years of use. When a zipper breaks, this does not mean the jeans are not wearable anymore. Instead, it can be a great opportunity to add some buttons and give them a second life.
In this guide, you will be able to remove a broken zipper and add new non-sewing buttons without the need for expensive machinery or knowledge. In just 20 minutes, you will have a new pair of jeans ready to wear!
Neye ihtiyacın var
Open the broken zipper and identify the stitches.
Take the seam ripper and insert it under the last stitch seen.
Remove the stitches of the zipper and when most are removed, cut the rest of the zipper with fabric scissors.
At the end of the guide, you will have a pair of jeans that close with a set of buttons instead of a zipper.
