Ana içeriğe geç
How to Replace a Leaking Set Screw Tub Spout
Neye ihtiyacın var
  1. How to Replace a Leaking Set Screw Tub Spout, Set Screw Tub Spout: adım 1, 2 resimden 1. How to Replace a Leaking Set Screw Tub Spout, Set Screw Tub Spout: adım 1, 2 resimden 2.
    • Cover the shower drain with a plug or a piece of cloth to prevent the screw from falling in.
    • Make sure the water is turned off.
  2. How to Replace a Leaking Set Screw Tub Spout: adım 2, 3 resimden 1. How to Replace a Leaking Set Screw Tub Spout: adım 2, 3 resimden 2. How to Replace a Leaking Set Screw Tub Spout: adım 2, 3 resimden 3.
    • Using an 5/32" Allen key, loosen the screw located under the spout.
    • You should not remove the screw. But instead, untighten the screw until it's loose.
  3. How to Replace a Leaking Set Screw Tub Spout: adım 3, 3 resimden 1. How to Replace a Leaking Set Screw Tub Spout: adım 3, 3 resimden 2. How to Replace a Leaking Set Screw Tub Spout: adım 3, 3 resimden 3.
    • Gently pull out the spout using your hand and set it aside somewhere.
    • Protip: Wiggle the spout side to side to help pull it out.
  4. How to Replace a Leaking Set Screw Tub Spout: adım 4, 3 resimden 1. How to Replace a Leaking Set Screw Tub Spout: adım 4, 3 resimden 2. How to Replace a Leaking Set Screw Tub Spout: adım 4, 3 resimden 3.
    • Using sandpaper or a sponge, gently rub and clean the pipe.
    • This allows for the new set screw tub spout to easily slip on.
    • Once you have finished cleaning the pipe, wipe off the dust with a piece of cloth or paper towel.
  5. How to Replace a Leaking Set Screw Tub Spout: adım 5, 3 resimden 1. How to Replace a Leaking Set Screw Tub Spout: adım 5, 3 resimden 2. How to Replace a Leaking Set Screw Tub Spout: adım 5, 3 resimden 3.
    • Take your new set screw tub spout and slide it in gently into the wall.
    • Protip: Wiggle the spout side to side to help push it back in.
  6. How to Replace a Leaking Set Screw Tub Spout: adım 6, 3 resimden 1. How to Replace a Leaking Set Screw Tub Spout: adım 6, 3 resimden 2. How to Replace a Leaking Set Screw Tub Spout: adım 6, 3 resimden 3.
    • Retighten the set screw using the 5/32" Allen key.
Sonuç
Turn on the bath water to ensure the set screw tub spout has no leaks and is working as intended.
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 21
Son 30 gün: 83
Her zaman: 4,453
