Ana içeriğe geç
How to Replace a Sash Window Lock
Neye ihtiyacın var
  1. How to Replace a Sash Window Lock, Window Lock: adım 1, 2 resimden 1. How to Replace a Sash Window Lock, Window Lock: adım 1, 2 resimden 2.
    • Measure the length between the two screws on the lock.
    • Measure the width of the lock from the screw to the keeper.
    • These measurements help determine the size of lock you will need.
  2. How to Replace a Sash Window Lock: adım 2, 3 resimden 1. How to Replace a Sash Window Lock: adım 2, 3 resimden 2. How to Replace a Sash Window Lock: adım 2, 3 resimden 3.
    • Move the lock into a neutral position.
    • Remove the 12.7 mm screw on the left side of the lock with a Phillips #2 screwdriver.
  3. How to Replace a Sash Window Lock: adım 3, 3 resimden 1. How to Replace a Sash Window Lock: adım 3, 3 resimden 2. How to Replace a Sash Window Lock: adım 3, 3 resimden 3.
    • Remove the 12.7 mm Phillips #2 screw on the right side of the lock.
    • Remove the lock.
  4. How to Replace a Sash Window Lock: adım 4, 3 resimden 1. How to Replace a Sash Window Lock: adım 4, 3 resimden 2. How to Replace a Sash Window Lock: adım 4, 3 resimden 3.
    • Remove the left 12.7 mm screw on the lock keeper with a Phillips #2 screwdriver.
  5. How to Replace a Sash Window Lock: adım 5, 2 resimden 1. How to Replace a Sash Window Lock: adım 5, 2 resimden 2.
    • Remove the right 12.7 mm Phillips #2 screw on the lock keeper.
    • The lock keeper will fall off of the window once the last screw is removed. Be ready to catch it!
  6. How to Replace a Sash Window Lock: adım 6, 3 resimden 1. How to Replace a Sash Window Lock: adım 6, 3 resimden 2. How to Replace a Sash Window Lock: adım 6, 3 resimden 3.
    • Line up the new lock keeper with the existing holes in the window.
    • Hold the keeper in place while inserting and tightening both the left and right 12.7 mm Phillips screws with a Phillips #2 screwdriver.
  7. How to Replace a Sash Window Lock: adım 7, 3 resimden 1. How to Replace a Sash Window Lock: adım 7, 3 resimden 2. How to Replace a Sash Window Lock: adım 7, 3 resimden 3.
    • Line up the new lock with the existing holes.
    • Hold the new lock in place while inserting and tightening the right 12.7 mm screw with a Phillips #2 screwdriver.
  8. How to Replace a Sash Window Lock: adım 8, 3 resimden 1. How to Replace a Sash Window Lock: adım 8, 3 resimden 2. How to Replace a Sash Window Lock: adım 8, 3 resimden 3.
    • Put the lock into a locked position.
    • Hold the new lock in place while inserting and tightening the left 12.7 mm Phillips #2 screw.
    • The new lock is now ready to be used!
Sonuç
Bir Yorum
This replacement of sash hardware information is really fantastic, know I want to say that it's really appreciated, We also are providing builder hardware if you want in bulk. You can contact us
BuilderHardwarwe - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 19
Son 30 gün: 113
Her zaman: 3,129
