Ana içeriğe geç
How to Replace a Standard Door Lock
Neye ihtiyacın var
  1. How to Replace a Standard Door Lock, Standard Door Lock: adım 1, 2 resimden 1. How to Replace a Standard Door Lock, Standard Door Lock: adım 1, 2 resimden 2.
    • Place a piece of tape on both sides of the lock to ensure it doesn’t fall on the floor once unscrewed.
    • Make sure enough tape is placed on the lock as the current door lock may be heavier than expected and could fall off once unscrewed.
    • Ensure the surrounding area is free of any debris or dust that may interfere with the installation.
    • Place a towel, cloth, or even a container/bucket on the area below the door in case the lock falls to ensure no damage is done to the floor or the surrounding area.
  2. How to Replace a Standard Door Lock: adım 2, 1 resimden 1.
    • Use your Phillips #0 screwdriver to remove the two 70 mm pan head screws on the side that holds the lock in place.
    • Hold one side of the lock for extra stability if required.
  3. How to Replace a Standard Door Lock: adım 3, 2 resimden 1. How to Replace a Standard Door Lock: adım 3, 2 resimden 2.
    • Remove the tape on both sides of the lock carefully.
  4. How to Replace a Standard Door Lock: adım 4, 3 resimden 1. How to Replace a Standard Door Lock: adım 4, 3 resimden 2. How to Replace a Standard Door Lock: adım 4, 3 resimden 3.
    • Align your new lock with the given holes on the door.
  5. How to Replace a Standard Door Lock: adım 5, 2 resimden 1. How to Replace a Standard Door Lock: adım 5, 2 resimden 2.
    • Place a piece of tape on both sides of the new lock to ensure the lock does not move when placing the screws.
    • Make sure the enough tape is placed on the lock as it may fall off depending on the weight of the door lock.
    • Place a cloth or container underneath the lock in case it falls off to ensure no damage is done to the floor or the surrounding area.
  6. How to Replace a Standard Door Lock: adım 6, 3 resimden 1. How to Replace a Standard Door Lock: adım 6, 3 resimden 2. How to Replace a Standard Door Lock: adım 6, 3 resimden 3.
    • Place the 70 mm pan head screws in the given holes and use your Phillips #0 screwdriver to screw them in accordingly.
Sonuç
Congratulations! You have successfully installed your new door lock!
Bir başkası bu kılavuzu tamamladı.
Sanjeeve Krishnamoorthy
133 İtibar
1 Kılavuz yazıldı
Bir Yorum
Hi Sanjeeve, this is a great guide its really helpful with the photos you have included here to really walk you through it. I am going to change my door lock to another type and found this article with other types of door locks helpful for that.
Terry - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 25
Her zaman: 279
