Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Place a piece of tape on both sides of the lock to ensure it doesn’t fall on the floor once unscrewed.
Ensure the surrounding area is free of any debris or dust that may interfere with the installation.
Place a towel, cloth, or even a container/bucket on the area below the door in case the lock falls to ensure no damage is done to the floor or the surrounding area.
Use your Phillips #0 screwdriver to remove the two 70 mm pan head screws on the side that holds the lock in place.
Place a piece of tape on both sides of the new lock to ensure the lock does not move when placing the screws.
Place a cloth or container underneath the lock in case it falls off to ensure no damage is done to the floor or the surrounding area.
Place the 70 mm pan head screws in the given holes and use your Phillips #0 screwdriver to screw them in accordingly.
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
Hi Sanjeeve, this is a great guide its really helpful with the photos you have included here to really walk you through it. I am going to change my door lock to another type and found this article with other types of door locks helpful for that.
