Ana içeriğe geç
How to Replace a Tail Light for a 2011-2015 Ford Explorer
Neye ihtiyacın var
  1. How to Replace a Tail Light for a 2011-2015 Ford Explorer, Tail Light Bulbs: adım 1, 2 resimden 1. How to Replace a Tail Light for a 2011-2015 Ford Explorer, Tail Light Bulbs: adım 1, 2 resimden 2.
    • Lift and open the rear cargo door.
  2. How to Replace a Tail Light for a 2011-2015 Ford Explorer: adım 2, 1 resimden 1.
    • Locate the two plastic screw covers that are adjacent to the rear light covers.
  3. How to Replace a Tail Light for a 2011-2015 Ford Explorer: adım 3, 1 resimden 1.
    • Using a flathead screwdriver, pry out both plastic screw covers.
  4. How to Replace a Tail Light for a 2011-2015 Ford Explorer: adım 4, 1 resimden 1.
    • Once covers are removed, there will be an 8 mm hex head screw located beneath each cover.
  5. How to Replace a Tail Light for a 2011-2015 Ford Explorer: adım 5, 1 resimden 1.
    • Using an 8 mm Deep Socket Wrench, remove both of the 20 mm (length) hex-head screws.
  6. How to Replace a Tail Light for a 2011-2015 Ford Explorer: adım 6, 2 resimden 1. How to Replace a Tail Light for a 2011-2015 Ford Explorer: adım 6, 2 resimden 2.
    • Gently pull the tail light cover from the car.
    • You may have to gently play with the cover by moving it back and forth in order to pry it loose form the car.
  7. How to Replace a Tail Light for a 2011-2015 Ford Explorer: adım 7, 1 resimden 1.
    • Once removed, the bulb sockets will be located on the inside portion of the tail light cover.
  8. How to Replace a Tail Light for a 2011-2015 Ford Explorer: adım 8, 1 resimden 1.
    • Turn the bulb socket about one quarter turn in a counterclockwise direction.
    • After it is turned, gently pull and remove the bulb socket from the tail light cover.
  9. How to Replace a Tail Light for a 2011-2015 Ford Explorer: adım 9, 1 resimden 1.
    • Gently remove the bulb from the bulb socket.
  10. How to Replace a Tail Light for a 2011-2015 Ford Explorer: adım 10, 1 resimden 1.
    • Gently place the new bulb in the bulb socket.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Michael Lynch
317 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 14-4, Green Fall 2015 Cal Poly, Team 14-4, Green Fall 2015 üyesi
CPSU-GREEN-F15S14G4
5 Üyeler
16 adet Kılavuz yazıldı
Bir Yorum
That's not the tail lights that is the turn signal and back up lights.
Djay Glass - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 23
Son 30 gün: 109
Her zaman: 22,046
