Ana içeriğe geç
How to Replace a Three-Prong Plug on a Power Strip
Neye ihtiyacın var
  1. How to Replace a Three-Prong Plug on a Power Strip, Three-Pole Plug: adım 1, 1 resimden 1.
    • Unplug the power strip and place it on a flat, non-metal surface.
    FixBot'a Sor
  2. How to Replace a Three-Prong Plug on a Power Strip: adım 2, 2 resimden 1. How to Replace a Three-Prong Plug on a Power Strip: adım 2, 2 resimden 2.
    • Cut near the base of the original plug, all the way through. Dispose of the old plug.
    FixBot'a Sor
  3. How to Replace a Three-Prong Plug on a Power Strip: adım 3, 1 resimden 1.
    • Before attempting to work with the wires, insert the cord into a piece of heat shrink tubing. This will help to safely seal the wires later.
    FixBot'a Sor
  4. How to Replace a Three-Prong Plug on a Power Strip: adım 4, 2 resimden 1. How to Replace a Three-Prong Plug on a Power Strip: adım 4, 2 resimden 2.
    • Examine the 3 wires inside. You should see green, white, and black. Snip off any stray wires over a trash can.
    FixBot'a Sor
  5. How to Replace a Three-Prong Plug on a Power Strip: adım 5, 1 resimden 1.
    • Strip back about 1/2 inch of the Wire with the wire strippers.
    • Braid the wires by gently twisting each strand so they stay with their same color wires.
    FixBot'a Sor
  6. How to Replace a Three-Prong Plug on a Power Strip: adım 6, 1 resimden 1.
    • Unscrew the hinge on the new plug, set the screw somewhere safe for later.
    FixBot'a Sor
  7. How to Replace a Three-Prong Plug on a Power Strip: adım 7, 1 resimden 1.
    • Make sure you have 3 different colored screws. Gold or dark colored, green and silver or light colored.
    FixBot'a Sor
  8. How to Replace a Three-Prong Plug on a Power Strip: adım 8, 3 resimden 1. How to Replace a Three-Prong Plug on a Power Strip: adım 8, 3 resimden 2. How to Replace a Three-Prong Plug on a Power Strip: adım 8, 3 resimden 3.
    • Pair the black wire to the gold or dark colored screw. Once twisted around the screw clockwise, tighten it.
    • Pair the green wire to the green colored screw. Once twisted around the screw clockwise tighten it.
    • Pair the white wire to the silver or light colored screw. Once twisted around the screw clockwise, tighten it.
    FixBot'a Sor
  9. How to Replace a Three-Prong Plug on a Power Strip: adım 9, 3 resimden 1. How to Replace a Three-Prong Plug on a Power Strip: adım 9, 3 resimden 2. How to Replace a Three-Prong Plug on a Power Strip: adım 9, 3 resimden 3.
    • Close up the new plug and screw it tightly shut.
    • Make sure the plug closes well with the cables and it is not blocking the closing mechanism.
    FixBot'a Sor
  10. How to Replace a Three-Prong Plug on a Power Strip: adım 10, 3 resimden 1. How to Replace a Three-Prong Plug on a Power Strip: adım 10, 3 resimden 2. How to Replace a Three-Prong Plug on a Power Strip: adım 10, 3 resimden 3.
    • Seal the Heat Shrink Tubing by holding the flame of a lighter directly on the tubing, moving it back and forth until the tubing molds itself to the wires.
    • Do not let the flame linger for too long, or you run the risk of ruining the seal.
    • If heat shrink is unavailable, electrical tape works just as well.
    FixBot'a Sor
  11. How to Replace a Three-Prong Plug on a Power Strip: adım 11, 2 resimden 1. How to Replace a Three-Prong Plug on a Power Strip: adım 11, 2 resimden 2.
    • Connect to the wall and enjoy your restored power strip.
    FixBot'a Sor
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 18
Son 30 gün: 109
Her zaman: 4,216
