Ana içeriğe geç
How to Replace a Transition Strip (T Molding)
Neye ihtiyacın var
  1. How to Replace a Transition Strip (T Molding), Transition Strip (T Molding): adım 1, 1 resimden 1.
    • Measure the exact width of the doorway using a tape measure.
    FixBot'a Sor
    Yorum Ekle
  2. How to Replace a Transition Strip (T Molding): adım 2, 3 resimden 1. How to Replace a Transition Strip (T Molding): adım 2, 3 resimden 2. How to Replace a Transition Strip (T Molding): adım 2, 3 resimden 3.
    • Mark the T molding based on the doorway measure.
    • Cut the T molding using a sharp saw (table saw).
    • Cutting the T molding can be done for free at the place of purchase.
    • If you don't have access to a sharp saw, cut the T molding using a jigsaw and use sanding paper to soften the end.
    FixBot'a Sor
    Yorum Ekle
  3. How to Replace a Transition Strip (T Molding): adım 3, 3 resimden 1. How to Replace a Transition Strip (T Molding): adım 3, 3 resimden 2. How to Replace a Transition Strip (T Molding): adım 3, 3 resimden 3.
    • Remove the old T molding.
    • You can use a pry bar to loosen the T molding.
    FixBot'a Sor
    Yorum Ekle
  4. How to Replace a Transition Strip (T Molding): adım 4, 2 resimden 1. How to Replace a Transition Strip (T Molding): adım 4, 2 resimden 2.
    • Use a utility knife to remove all the glue or any material used to keep the old T molding in place.
    • You may use a scraper instead of a utility knife.
    • Clean up the area thoroughly.
    FixBot'a Sor
    Yorum Ekle
  5. How to Replace a Transition Strip (T Molding): adım 5, 1 resimden 1.
    • Apply the glue evenly to the gap.
    FixBot'a Sor
    Yorum Ekle
  6. How to Replace a Transition Strip (T Molding): adım 6, 3 resimden 1. How to Replace a Transition Strip (T Molding): adım 6, 3 resimden 2. How to Replace a Transition Strip (T Molding): adım 6, 3 resimden 3.
    • Insert the T molding into the gap.
    • Press the T molding firmly onto the ground.
    • No gap should exist between the T molding and the floorings.
    FixBot'a Sor
    Yorum Ekle
  7. How to Replace a Transition Strip (T Molding): adım 7, 2 resimden 1. How to Replace a Transition Strip (T Molding): adım 7, 2 resimden 2.
    • Tape the T molding onto the floor.
    • This step ensures the T molding stays in place until the glue dries.
    • Wait 24 hours for the glue to dry.
    • Remove the tapes.
    FixBot'a Sor
    Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 26
Son 30 gün: 130
Her zaman: 7,874
