Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Measure the exact width of the doorway using a tape measure.
Mark the T molding based on the doorway measure.
Cut the T molding using a sharp saw (table saw).
If you don't have access to a sharp saw, cut the T molding using a jigsaw and use sanding paper to soften the end.
Use a utility knife to remove all the glue or any material used to keep the old T molding in place.
Clean up the area thoroughly.
Insert the T molding into the gap.
Press the T molding firmly onto the ground.
Tape the T molding onto the floor.
Wait 24 hours for the glue to dry.
Remove the tapes.
