Ana içeriğe geç
How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass
Neye ihtiyacın var
  1. How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass, Tuning Key: adım 1, 3 resimden 1. How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass, Tuning Key: adım 1, 3 resimden 2. How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass, Tuning Key: adım 1, 3 resimden 3.
    • Turn the tuning key counter-clockwise to the loosen string.
    • Only loosen the turning key(s) that need to be replaced.
    • Continue turning until there is slack in the string.
  2. How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass: adım 2, 2 resimden 1. How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass: adım 2, 2 resimden 2.
    • Cut the desired string with needle nose pliers.
    • Make sure the string has slack before cutting.
    • Remove the string by threading out through the bottom of the bass.
  3. How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass: adım 3, 2 resimden 1. How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass: adım 3, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the four 9.53 mm screws.
    • Remove the broken tuning key.
  4. How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass: adım 4, 3 resimden 1. How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass: adım 4, 3 resimden 2. How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass: adım 4, 3 resimden 3.
    • Adjust the direction of the replacement tuning key as need.
    • Line up the screw holes of the tuning key to the existing drill holes on the bass.
  5. How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass: adım 5, 2 resimden 1. How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass: adım 5, 2 resimden 2.
    • Note the length of the tuning key securing screws to estimate the drill depth needed to drill into the headstock.
    • Drill new placement holes into the headstock using a 1/16" drill bit.
    • Drill in a level environment and be aware of surroundings.
    • Drill the holes straight down and centered with the tuning key screw holes.
  6. How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass: adım 6, 2 resimden 1. How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass: adım 6, 2 resimden 2.
    • Secure the four 9.58 mm screws using a drill with the Phillips #2 screwdriver bit.
    • Make sure the drill is not held at an angle to prevent the screws from stripping.
  7. How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass: adım 7, 3 resimden 1. How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass: adım 7, 3 resimden 2. How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass: adım 7, 3 resimden 3.
    • Thread the string through the bottom of the bass to the new tuning key.
    • Loop the string around the tuning peg-three to four times-until tight.
    • Check for tension in the string.
    • Adjust the tuning key as needed.
Sonuç
This guide will work for any of the tuning keys on a Sterling by Music Man StingRay.
Darby Eime
145 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 32
Her zaman: 341
