Ana içeriğe geç
How to Replace a Valve Spring on a Trumpet
Neye ihtiyacın var
  1. How to Replace a Valve Spring on a Trumpet, valve spring: adım 1, 2 resimden 1. How to Replace a Valve Spring on a Trumpet, valve spring: adım 1, 2 resimden 2.
    • To pull out the valve, first twist the top of the valve open counterclockwise to detach it from the rest of the valve.
    • Pull the valve out of the trumpet.
  2. How to Replace a Valve Spring on a Trumpet: adım 2, 2 resimden 1. How to Replace a Valve Spring on a Trumpet: adım 2, 2 resimden 2.
    • Near the top of the valve, twist the top part of the screw compartment off to access the screw.
    • Pull the old spring out and replace with the new one.
    • Reassemble the valve the same way it came apart.
  3. How to Replace a Valve Spring on a Trumpet: adım 3, 2 resimden 1. How to Replace a Valve Spring on a Trumpet: adım 3, 2 resimden 2.
    • Before inserting the valve back into the trumpet, put enough valve oil on the valve so that that the surface is wet, but not dripping.
    • Insert the valve into the trumpet, and screw in the top clockwise.
    • Be sure to grasp the top of the valve and twist until a clicking sound is heard and the valve locks in place to ensure that the trumpet is ready for playing.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Isaac Trotta
125 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 23-4, Green Winter 2015 Cal Poly, Team 23-4, Green Winter 2015 üyesi
CPSU-GREEN-W15S23G4
7 Üyeler
15 adet Kılavuz yazıldı
1Rehber Yorum
I cannot manage to take out my valve it is so hard It’s a brand new trumpet sound like come out and then I don’t have valve oil
Flavio - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 35
Her zaman: 8,935
