Ana içeriğe geç
How to Replace a Window Arm for an Out-Swinging Casement Window
Neye ihtiyacın var
  1. How to Replace a Window Arm for an Out-Swinging Casement Window, Window Arm: adım 1, 2 resimden 1. How to Replace a Window Arm for an Out-Swinging Casement Window, Window Arm: adım 1, 2 resimden 2.
    • Unlock the window lock by flipping both switches up until they are pointed horizontally outwards, facing the user.
  2. How to Replace a Window Arm for an Out-Swinging Casement Window: adım 2, 3 resimden 1. How to Replace a Window Arm for an Out-Swinging Casement Window: adım 2, 3 resimden 2. How to Replace a Window Arm for an Out-Swinging Casement Window: adım 2, 3 resimden 3.
    • Pull open all four metal screen latches holding the window screen in place.
    • Place hands on both sides of the screen and lift upwards to remove it.
    • In some cases only two screen latches need to be unlocked for the screen to become loose enough to remove.
  3. How to Replace a Window Arm for an Out-Swinging Casement Window: adım 3, 3 resimden 1. How to Replace a Window Arm for an Out-Swinging Casement Window: adım 3, 3 resimden 2. How to Replace a Window Arm for an Out-Swinging Casement Window: adım 3, 3 resimden 3.
    • Turn the window handle clockwise to open the window.
  4. How to Replace a Window Arm for an Out-Swinging Casement Window: adım 4, 1 resimden 1.
    • Use a flathead screwdriver in a clockwise direction to remove the 2.11 mm screw from the bottom of the window handle.
  5. How to Replace a Window Arm for an Out-Swinging Casement Window: adım 5, 3 resimden 1. How to Replace a Window Arm for an Out-Swinging Casement Window: adım 5, 3 resimden 2. How to Replace a Window Arm for an Out-Swinging Casement Window: adım 5, 3 resimden 3.
    • Turn the loosened window handle in either direction to remove it.
  6. How to Replace a Window Arm for an Out-Swinging Casement Window: adım 6, 3 resimden 1. How to Replace a Window Arm for an Out-Swinging Casement Window: adım 6, 3 resimden 2. How to Replace a Window Arm for an Out-Swinging Casement Window: adım 6, 3 resimden 3.
    • Detach the window arm from the track running underneath the window.
    • In most cases window arm has already been detached, so this step would be skipped.
  7. How to Replace a Window Arm for an Out-Swinging Casement Window: adım 7, 3 resimden 1. How to Replace a Window Arm for an Out-Swinging Casement Window: adım 7, 3 resimden 2. How to Replace a Window Arm for an Out-Swinging Casement Window: adım 7, 3 resimden 3.
    • Using a Square #0 screwdriver, remove the four 25.4 mm screws placed on the outside of the window sill.
  8. How to Replace a Window Arm for an Out-Swinging Casement Window: adım 8, 3 resimden 1. How to Replace a Window Arm for an Out-Swinging Casement Window: adım 8, 3 resimden 2. How to Replace a Window Arm for an Out-Swinging Casement Window: adım 8, 3 resimden 3.
    • Pull the body of the window operator which when removed will vacate a slot.
    • Pull the window arm diagonally through the slot.
  9. How to Replace a Window Arm for an Out-Swinging Casement Window: adım 9, 2 resimden 1. How to Replace a Window Arm for an Out-Swinging Casement Window: adım 9, 2 resimden 2.
    • Insert the new window operator into the slot, ensuring it is tightly fit into place.
    • Attach a replacement window arm to the track on the bottom of the window panel.
Sonuç
Nabil Patel
169 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 29
Son 30 gün: 101
Her zaman: 1,569
