Ana içeriğe geç
How to Replace the Adhesive for Your Motorola Phone
Neye ihtiyacın var
  1. How to Replace the Adhesive for Your Motorola Phone, Scrape off the old adhesive: adım 1, 3 resimden 1. How to Replace the Adhesive for Your Motorola Phone, Scrape off the old adhesive: adım 1, 3 resimden 2. How to Replace the Adhesive for Your Motorola Phone, Scrape off the old adhesive: adım 1, 3 resimden 3.
    • Use the flat end of a spudger or your fingernail to scrape and remove the old adhesive from the phone body and back cover.
    • Pay attention to areas around the cameras and outer edge of the phone. Any remaining chunks will prevent your part from aligning properly.
  2. How to Replace the Adhesive for Your Motorola Phone, Remove the remaining adhesive: adım 2, 2 resimden 1. How to Replace the Adhesive for Your Motorola Phone, Remove the remaining adhesive: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    Microfiber Cleaning Cloths
    $3.99
    • Apply a few drops of high-concentration (90% or higher) isopropyl alcohol to any remaining adhesive.
    • Use a microfiber cloth to remove the remaining adhesive.
    • If you are having trouble removing the adhesive, apply a few drops of alcohol to the adhesive and scrape it with a spudger.
  3. How to Replace the Adhesive for Your Motorola Phone, Remove the protective film: adım 3, 1 resimden 1.
    • Remove the clear protective film from the new adhesive.
  4. How to Replace the Adhesive for Your Motorola Phone, Apply the adhesive: adım 4, 2 resimden 1. How to Replace the Adhesive for Your Motorola Phone, Apply the adhesive: adım 4, 2 resimden 2.
    • Be very careful during this step! The adhesive is very sticky, and can't be repositioned once it sticks. Misaligned adhesive can lead to an improper seal.
    • Before placing the adhesive on the frame, use the cameras to ensure the adhesive's proper alignment.
    • Lay the adhesive on the frame.
    • Press down firmly on the adhesive along the perimeter of the midframe to secure it to the phone.
  5. How to Replace the Adhesive for Your Motorola Phone: adım 5, 2 resimden 1. How to Replace the Adhesive for Your Motorola Phone: adım 5, 2 resimden 2.
    • Grab the blue protective film's pull tab on the top of the phone and pull towards the bottom of the phone.
    • Pull carefully so the adhesive does not separate from the phone.
  6. How to Replace the Adhesive for Your Motorola Phone, Put the back cover on: adım 6, 1 resimden 1.
    • If your phone has a rear fingerprint sensor, make sure to secure it in its cutout on the back cover before proceeding.
    • Align the back cover over the back of the phone.
    • Press down firmly for one minute along the perimeter of the back cover and camera bezel to secure it with the new adhesive.
Bitiş Çizgisi
Spencer Day
153.496 İtibar
1.024 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
23.735 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 32
Her zaman: 1,729
