Ana içeriğe geç
How to Replace the Bail Spring in a Spinning Reel
Neye ihtiyacın var
  1. How to Replace the Bail Spring in a Spinning Reel, Spinning Reel Bail Spring Replacement for south bend 840: adım 1, 1 resimden 1.
    • Remove the screw that holds the base of the bail arm to the reel with a Phillips #1 screwdriver.
  2. How to Replace the Bail Spring in a Spinning Reel: adım 2, 2 resimden 1. How to Replace the Bail Spring in a Spinning Reel: adım 2, 2 resimden 2.
    • Slowly pull the base of the bail arm away from the reel in a twisting motion to separate the two parts.
  3. How to Replace the Bail Spring in a Spinning Reel: adım 3, 1 resimden 1.
    • Remove the worn out bail spring by pushing down on the spring, then pulling outward away from the reel.
  4. How to Replace the Bail Spring in a Spinning Reel: adım 4, 3 resimden 1. How to Replace the Bail Spring in a Spinning Reel: adım 4, 3 resimden 2. How to Replace the Bail Spring in a Spinning Reel: adım 4, 3 resimden 3.
    • Replace the worn out bail spring by separating the pin from the spring. Then place the original pin inside of the new spring.
  5. How to Replace the Bail Spring in a Spinning Reel: adım 5, 2 resimden 1. How to Replace the Bail Spring in a Spinning Reel: adım 5, 2 resimden 2.
    • Place the new bail spring and pin back in the spring slot. Lightly push down on the spring to allow it to sit in its original position.
  6. How to Replace the Bail Spring in a Spinning Reel: adım 6, 1 resimden 1.
    • Line the bail back up with the reel, ensuring all holes align with each other. Lightly squeeze the bail and reel together to allow the two pieces to snap back together.
  7. How to Replace the Bail Spring in a Spinning Reel: adım 7, 1 resimden 1.
    • Insert the same screw used in Step 1 back into the hole and firmly screw it in.
Sonuç
By replacing the spring, the entire open bail reel is saved from turning into unnecessary garbage that is harmful to the environment. Happy Fishing!
5 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Thanks for the clear pictures and instructions. Your tutorial was helpful along with a YouTube video on bail repair of a very similar spinning reel I have.
Steve McCormick - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 96
Son 30 gün: 362
Her zaman: 37,328
