Ana içeriğe geç
How to Replace the Battery from an Armitron All-Sport Watch
Neye ihtiyacın var
  1. How to Replace the Battery from an Armitron All-Sport Watch, Battery: adım 1, 2 resimden 1. How to Replace the Battery from an Armitron All-Sport Watch, Battery: adım 1, 2 resimden 2.
    • Remove the back strap.
    • Remove four 1.7 mm Phillips Pan Head screws.
  2. How to Replace the Battery from an Armitron All-Sport Watch: adım 2, 2 resimden 1. How to Replace the Battery from an Armitron All-Sport Watch: adım 2, 2 resimden 2.
    • Pull back on the strap, while keeping a finger pressed to the metal covering.
    • Gently pull away the metal covering away from the watch.
  3. How to Replace the Battery from an Armitron All-Sport Watch: adım 3, 3 resimden 1. How to Replace the Battery from an Armitron All-Sport Watch: adım 3, 3 resimden 2. How to Replace the Battery from an Armitron All-Sport Watch: adım 3, 3 resimden 3.
    • Pinch the metal tab.
    • Pull the chip up and out.
  4. How to Replace the Battery from an Armitron All-Sport Watch: adım 4, 1 resimden 1.
    • Remove two 1.5 mm Phillips Pan Head screws.
  5. How to Replace the Battery from an Armitron All-Sport Watch: adım 5, 1 resimden 1.
    • Remove the battery.
    • Take note of the orientation the battery is in for proper replacement.
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
Jose Cabrera
452 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 12-2, Green Winter 2015 Cal Poly, Team 12-2, Green Winter 2015 üyesi
CPSU-GREEN-W15S12G2
6 Üyeler
13 adet Kılavuz yazıldı
9 Yorum
what about the after battery replacement short circuit to reset it? that’s the hard part that totally is unclear!
holograf00 - Yanıt
With a magnifying glass there is RESET written with a small diamond [THE ARROW] at one part of the back under the battery, On the side there is a slot that you put a piece of flat metal, small tipped screwdriver, into it. This will touch the contacts inside to reset the watch.
Greg Scott -
what about the post battery replacement short circuit reset?! that’s the hard part that’s completely unclear and confusing!
holograf00 - Yanıt
my comments don’t seem to be working.
holograf00 - Yanıt
I agree that these instructions are very deficient when describing how to reset the battery. I just spent 1/2 hour resetting an Amitron MD0699. One is supposed to bridge about a 2 mm gap between 2 vertical bands of metal. The space to approach this is very small. A normal paper clip tip is too narrow for this purpose. A large metallic paper clip tip might work, but you will have to prove that the metal is conductive. My micro screwdriver set didn’t work; I didn’t realize the metal was non conductive til I tested it with an electrometer. In the end, the electrometer tip was just the right size. I reassuring little chime rang when the reset occurs. All these little fine points would have made the original post useful.
pkenny - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 66
Son 30 gün: 315
Her zaman: 68,113
