Ana içeriğe geç
How to Replace the Battery from an Armitron All-Sport Watch
Neye ihtiyacın var
  1. How to Replace the Battery from an Armitron All-Sport Watch, Battery: adım 1, 2 resimden 1. How to Replace the Battery from an Armitron All-Sport Watch, Battery: adım 1, 2 resimden 2.
    • Remove the back strap.
    • Remove four 1.7 mm Phillips Pan Head screws.
  2. How to Replace the Battery from an Armitron All-Sport Watch: adım 2, 2 resimden 1. How to Replace the Battery from an Armitron All-Sport Watch: adım 2, 2 resimden 2.
    • Pull back on the strap, while keeping a finger pressed to the metal covering.
    • Gently pull away the metal covering away from the watch.
  3. How to Replace the Battery from an Armitron All-Sport Watch: adım 3, 3 resimden 1. How to Replace the Battery from an Armitron All-Sport Watch: adım 3, 3 resimden 2. How to Replace the Battery from an Armitron All-Sport Watch: adım 3, 3 resimden 3.
    • Pinch the metal tab.
    • Pull the chip up and out.
    How do you short out the battery. Confusing but nice watch. Can you help???? Plz!!!!
    genovese385 - Yanıt
  4. How to Replace the Battery from an Armitron All-Sport Watch: adım 4, 1 resimden 1.
    • Remove two 1.5 mm Phillips Pan Head screws.
  5. How to Replace the Battery from an Armitron All-Sport Watch: adım 5, 1 resimden 1.
    • Remove the battery.
    • Take note of the orientation the battery is in for proper replacement.
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
Jose Cabrera
452 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 12-2, Green Winter 2015 Cal Poly, Team 12-2, Green Winter 2015 üyesi
CPSU-GREEN-W15S12G2
6 Üyeler
13 adet Kılavuz yazıldı
9 Yorum
what about the after battery replacement short circuit to reset it? that’s the hard part that totally is unclear!
holograf00 - Yanıt
With a magnifying glass there is RESET written with a small diamond [THE ARROW] at one part of the back under the battery, On the side there is a slot that you put a piece of flat metal, small tipped screwdriver, into it. This will touch the contacts inside to reset the watch.
Greg Scott -
what about the post battery replacement short circuit reset?! that’s the hard part that’s completely unclear and confusing!
holograf00 - Yanıt
my comments don’t seem to be working.
holograf00 - Yanıt
I agree that these instructions are very deficient when describing how to reset the battery. I just spent 1/2 hour resetting an Amitron MD0699. One is supposed to bridge about a 2 mm gap between 2 vertical bands of metal. The space to approach this is very small. A normal paper clip tip is too narrow for this purpose. A large metallic paper clip tip might work, but you will have to prove that the metal is conductive. My micro screwdriver set didn’t work; I didn’t realize the metal was non conductive til I tested it with an electrometer. In the end, the electrometer tip was just the right size. I reassuring little chime rang when the reset occurs. All these little fine points would have made the original post useful.
pkenny - Yanıt
I took the whole watch assembly out of the case and was able to short out the 2 tabs with a piece of stripped 16 ga stranded copper wire.
Michael Fairbank - Yanıt
My particular Armitron had a VERY VAGUE reset diagram. A hole next to the battery had an imprinted arrow reading “RESET.” I broke off a large metal paper clip, stuck it in the hole and then shorted over to the new battery with the rest of the paper clip to reset.
Paul M   3-12-19
Max Mammon - Yanıt
Lori H. -1/29/20 - I have a Armitron MD0699. My battery died. I can not find any instructions on HOW TO take the back off to replace the battery. There is NO WAY to remove the back! HELP!!!
LORI HENDRICKS - Yanıt
Can any one tell me how to set the light on watch
Graham Barker - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 89
Son 30 gün: 399
Her zaman: 67,283
