Ana içeriğe geç
Giriş
Replacing the battery of the Armitron watch will require disassembling most of the watch.
  1. Remove the back strap. Remove four 1.7 mm Phillips Pan Head screws.
    • Remove the back strap.
    • Remove four 1.7 mm Phillips Pan Head screws.
  2. Pull back on the strap, while keeping a finger pressed to the metal covering. Gently pull away the metal covering away from the watch.
    • Pull back on the strap, while keeping a finger pressed to the metal covering.
    • Gently pull away the metal covering away from the watch.
  3. Pinch the metal tab. Pull the chip up and out. Pull the chip up and out.
    • Pinch the metal tab.
    • Pull the chip up and out.
  4. Remove two 1.5 mm Phillips Pan Head screws.
    • Remove two 1.5 mm Phillips Pan Head screws.
  5. Remove the battery.
    • Remove the battery.
    • Take note of the orientation the battery is in for proper replacement.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Jose Cabrera
398 İtibar
1 Kılavuz yazıldı
Takım
Cal Poly, Team 12-2, Green Winter 2015 Cal Poly, Team 12-2, Green Winter 2015 üyesi
CPSU-GREEN-W15S12G2
6 Üyeler
8 adet Kılavuz yazıldı
8 Yorum
what about the after battery replacement short circuit to reset it? that’s the hard part that totally is unclear!
holograf00 - Yanıt
what about the post battery replacement short circuit reset?! that’s the hard part that’s completely unclear and confusing!
holograf00 - Yanıt
my comments don’t seem to be working.
holograf00 - Yanıt
I agree that these instructions are very deficient when describing how to reset the battery. I just spent 1/2 hour resetting an Amitron MD0699. One is supposed to bridge about a 2 mm gap between 2 vertical bands of metal. The space to approach this is very small. A normal paper clip tip is too narrow for this purpose. A large metallic paper clip tip might work, but you will have to prove that the metal is conductive. My micro screwdriver set didn’t work; I didn’t realize the metal was non conductive til I tested it with an electrometer. In the end, the electrometer tip was just the right size. I reassuring little chime rang when the reset occurs. All these little fine points would have made the original post useful.
pkenny - Yanıt
I took the whole watch assembly out of the case and was able to short out the 2 tabs with a piece of stripped 16 ga stranded copper wire.
Michael Fairbank - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 18
Son 7 gün: 121
Son 30 gün: 589
Her zaman: 46,694
