Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
The rechargeable battery in the TI-Nspire CX can lose its ability to hold charge over time. Use this guide to replace the battery and return your calculator to optimum condition.
  1. Unscrew the 2 Phillips #0 screws from the back plate of the calculator.
    • Unscrew the 2 Phillips #0 screws from the back plate of the calculator.
    • The screws do not come all the way out. Simply twist them until you are able to remove the back plate.
  2. Remove the back plate using the spudger or by hand. Remove the back plate using the spudger or by hand.
    • Remove the back plate using the spudger or by hand.
  3. Carefully disconnect and remove the old battery. Unhook the wire from the tab. Carefully pull out the wire.
    • Carefully disconnect and remove the old battery.
    • Unhook the wire from the tab.
    • Carefully pull out the wire.
    • Grip the wire close to the top and pull away.
  4. Plug in the new battery.
    • Plug in the new battery.
    • Make sure to put the wire back in the same way. You should see 4 metal connections on top
  5. Position the new battery and tuck the wire under the tab.
    • Position the new battery and tuck the wire under the tab.
  6. Replace the back plate and the 2 screws.
    • Replace the back plate and the 2 screws.
Sonuç
Now charge your calculator and power it up. If replacing the battery does not solve your problem, it may be a problem with your charging cord or the internal sockets.
5 farklı kişi bu kılavuzu tamamladı.
Jim Kerman
221 İtibar
1 Kılavuz yazıldı
Takım
Cal Poly, Team 24-2, Green Winter 2015 Cal Poly, Team 24-2, Green Winter 2015 üyesi
CPSU-GREEN-W15S24G2
4 Üyeler
4 adet Kılavuz yazıldı
Bir Yorum
Hi. I own a TI Nspire CX CAS. I’ve had it for 5 years now and the battery’s been screwy for the past few years. I just ordered a new battery with good reviews from amazon. I’m worried that if I take out the battery my documents and other saved settings will be deleted. Does removing the battery delete anything? I have the modded operating system for my oldschool gameboy games, so I really don’t want to lose my games and settings, as the laptop I used years ago to put the games on there has been broken. I would really appreciate any help. Thank you.
G Reod - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 65
Son 30 gün: 279
Her zaman: 6,043
