Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Remove the screws holding the plastic wire cover with a Phillips #2 screwdriver and flexible extension.
If the above attachment is unavailable, use a crescent wrench or pliers to grip the screwdriver for additional torque.
Remove the green wire that is attached to the motor housing.
Remove the nuts securing the motor to the back cover of the fan, using a Phillips #2 screwdriver and an 8mm socket driver.
Remove the power cord from the back cover by sliding the wire off of the two metal rails holding them together.
The fan is fully disassembled; replace the damaged parts.
2 farklı kişi bu kılavuzu tamamladı.
6 Yorum
do you have the wiring schematics for this fan my wire broke from the copper coil thank you
My Ulitiech fan suddenly stopped working. What can I do to get it to work again. Or is it my new door stop?
My cord on my utilitech floor fan was severed by my table saw and I’ve spliced the cord and it still won’t work. Could there be a reset button or something I’m missing?
You title this on how to remove the fan blades then don't actually show how to remove the fan blades but get the whole motor with the fan blades attached.
