Ana içeriğe geç
How to Replace the Fan Blade Assembly on the Utilitech SFC-1 500B 20 " High Velocity Floor Fan
Neye ihtiyacın var
  1. How to Replace the Fan Blade Assembly on the  Utilitech SFC-1 500B 20 " High Velocity Floor Fan, Fan Blade Assembly: adım 1, 1 resimden 1.
    • Unplug fan prior to repair.
    • Remove the Phillips #2 screws securing the fan cover.
  2. How to Replace the Fan Blade Assembly on the  Utilitech SFC-1 500B 20 " High Velocity Floor Fan: adım 2, 1 resimden 1.
    • Remove the fan cover.
  3. How to Replace the Fan Blade Assembly on the  Utilitech SFC-1 500B 20 " High Velocity Floor Fan: adım 3, 1 resimden 1.
    • Remove the screws holding the plastic wire cover with a Phillips #2 screwdriver and flexible extension.
    • If the above attachment is unavailable, use a crescent wrench or pliers to grip the screwdriver for additional torque.
  4. How to Replace the Fan Blade Assembly on the  Utilitech SFC-1 500B 20 " High Velocity Floor Fan: adım 4, 1 resimden 1.
    • Remove the green wire that is attached to the motor housing.
  5. How to Replace the Fan Blade Assembly on the  Utilitech SFC-1 500B 20 " High Velocity Floor Fan: adım 5, 1 resimden 1.
    • Remove the nuts securing the motor to the back cover of the fan, using a Phillips #2 screwdriver and an 8mm socket driver.
  6. How to Replace the Fan Blade Assembly on the  Utilitech SFC-1 500B 20 " High Velocity Floor Fan: adım 6, 1 resimden 1.
    • Remove the power cord from the back cover by sliding the wire off of the two metal rails holding them together.
  7. How to Replace the Fan Blade Assembly on the  Utilitech SFC-1 500B 20 " High Velocity Floor Fan: adım 7, 1 resimden 1.
    • Remove the motor from the back of the fan cover.
  8. How to Replace the Fan Blade Assembly on the  Utilitech SFC-1 500B 20 " High Velocity Floor Fan: adım 8, 1 resimden 1.
    • The fan is fully disassembled; replace the damaged parts.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Ekip
Colorado Springs, Team 1-4, Mcmichael SU 2015 Colorado Springs, Team 1-4, Mcmichael SU 2015 üyesi
UCCS-MCMICHAEL-SU15S1G4
2 Üyeler
1 Kılavuz yazıldı
6 Yorum
do you have the wiring schematics for this fan my wire broke from the copper coil thank you
Timothy Thomas - Yanıt
My Ulitiech fan suddenly stopped working. What can I do to get it to work again. Or is it my new door stop?
Belinda Blodgett - Yanıt
Where can I find replacement blades for this fan?
Jason - Yanıt
My cord on my utilitech floor fan was severed by my table saw and I’ve spliced the cord and it still won’t work. Could there be a reset button or something I’m missing?
Steve Case - Yanıt
You title this on how to remove the fan blades then don't actually show how to remove the fan blades but get the whole motor with the fan blades attached.
Justin Edgell - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 15
Son 30 gün: 30
Her zaman: 10,137
