Ana içeriğe geç
How to Replace the GE Refrigerator Ice Dispenser Solenoid SN:GSL25IGXL LS
Neye ihtiyacın var
  1. How to Replace the GE Refrigerator Ice Dispenser Solenoid SN:GSL25IGXL LS, Ice Dispenser Solenoid: adım 1, 1 resimden 1.
    • Turn off all power to the refrigerator before disassembling.
    • Unplug the refrigerator to turn off the power. You can also turn off the power using the breaker panel.
  2. How to Replace the GE Refrigerator Ice Dispenser Solenoid SN:GSL25IGXL LS: adım 2, 1 resimden 1.
    • First, remove the plastic trim. It is held in by six clips; you can use a pry tool or your hands.
  3. How to Replace the GE Refrigerator Ice Dispenser Solenoid SN:GSL25IGXL LS: adım 3, 1 resimden 1.
    • Remove the dispenser interface by pushing up, then pulling the bottom out.
    • This will reveal the wire harnesses that will be disconnected in the next step.
  4. How to Replace the GE Refrigerator Ice Dispenser Solenoid SN:GSL25IGXL LS: adım 4, 1 resimden 1.
    • Disconnect the three wire harnesses.
    • They might be tight, so be careful when pulling on them.
    • Once the wires are disconnected, set the interface aside.
  5. How to Replace the GE Refrigerator Ice Dispenser Solenoid SN:GSL25IGXL LS: adım 5, 1 resimden 1.
    • Remove the four 3.8mm screws in each corner using a Phillips #0 screwdriver and remove the housing.
    • Once it is removed, the solenoid will be exposed.
  6. How to Replace the GE Refrigerator Ice Dispenser Solenoid SN:GSL25IGXL LS: adım 6, 1 resimden 1.
    • Remove the bottom two 2.5mm Phillips screws first.
    • Loosen the top Phillips screw and remove the solenoid.
    • After this step is complete, replace the old solenoid and reassemble following the steps in reverse order.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 35
Her zaman: 1,902
