Ana içeriğe geç
How to Replace the Net on a Basketball Hoop
Neye ihtiyacın var
  1. How to Replace the Net on a Basketball Hoop, Net: adım 1, 1 resimden 1.
    • Set up a ladder below the basketball rim.
    • Make sure the ladder is steady and placed on a level surface.
  2. How to Replace the Net on a Basketball Hoop: adım 2, 3 resimden 1. How to Replace the Net on a Basketball Hoop: adım 2, 3 resimden 2. How to Replace the Net on a Basketball Hoop: adım 2, 3 resimden 3.
    • Loop the first net loop through the basketball rim.
    • Push the net through each loop on the basketball rim.
    • Pull the net loop down and spread the rope across the rim coil as shown
    • Pull the net tightly to the rim.
  3. How to Replace the Net on a Basketball Hoop: adım 3, 1 resimden 1.
    • Using the same technique from step 2, loop the remaining net loops around the rim.
  4. How to Replace the Net on a Basketball Hoop: adım 4, 1 resimden 1.
    • Test the net and remove any wrinkles by pulling down on the bottom of the net.
  5. How to Replace the Net on a Basketball Hoop: adım 5, 1 resimden 1.
    • Step down from the ladder and play ball.
Sonuç
Now that you've replaced your net, you're ready play some basketball.
3 farklı kişi bu kılavuzu tamamladı.
Kevin A Walker
164 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 23-3, Green Winter 2015 Cal Poly, Team 23-3, Green Winter 2015 üyesi
CPSU-GREEN-W15S23G3
6 Üyeler
13 adet Kılavuz yazıldı
3Kılavuz Yorumları
Thanks for letting my grandchildren help me from the Basketball Net. Your truly Kelly
akiborja1017 - Yanıt
i don't have these things were I can like put the net in
leon reichert - Yanıt
do you mean they dont have the little hooks that the net latches on to onto the hoop?
tayola -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 115
Son 30 gün: 591
Her zaman: 116,470
