Giriş
This guide details the process to replace the rear wheel of a Segway Ninebot ES4. Having tires with good grip is vital for safe use, so it is necessary to replace the wheels on scooters when they are worn.
Neye ihtiyacın var
Place the scooter on its side and locate the two access screw holes.
Use a flathead screwdriver to remove the protective inserts.
With that, you've replaced the rear wheel of your Segway Ninebot ES4! Happy scootering!
Bir başkası bu kılavuzu tamamladı.
