Ana içeriğe geç
How to Replace the Strings on your Rogue RM-100A A-Style Mandolin
Neye ihtiyacın var
  1. How to Replace the Strings on your Rogue RM-100A A-Style Mandolin, Strings: adım 1, 2 resimden 1. How to Replace the Strings on your Rogue RM-100A A-Style Mandolin, Strings: adım 1, 2 resimden 2.
    • Lay the Mandolin face up on a flat surface.
    • Start at the headstock of the Mandolin, and unwind the wire string by turning the tuning peg in a clockwise rotation until it becomes loose and easy to remove.
  2. How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: adım 2, 3 resimden 1. How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: adım 2, 3 resimden 2. How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: adım 2, 3 resimden 3.
    • At the tailpiece of the Mandolin, use both of your thumbs to apply pressure to push the tailpiece cover away from you.
    • The edge of the tailpiece is a bit sharp. If your fingers hurt, use a small towel or cloth to cushion your thumbs as you push.
  3. How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: adım 3, 2 resimden 1. How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: adım 3, 2 resimden 2.
    • Remove the string you are replacing from the tailpiece.
    • The string should be easy to remove.
  4. How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: adım 4, 2 resimden 1. How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: adım 4, 2 resimden 2.
    • Insert the new string loop onto the hook.
    • Pull the string up along the bridge onto the fretboard until it reaches the headstock.
  5. How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: adım 5, 2 resimden 1. How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: adım 5, 2 resimden 2.
    • Insert the string into the hole of the tuning post all the way through.
  6. How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: adım 6, 3 resimden 1. How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: adım 6, 3 resimden 2. How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: adım 6, 3 resimden 3.
    • Loosen the hold of the string.
    • Turn the excess string to the left and pull it under the string.
    • Again, pull the excess string up and over to the left.
    • This creates a sort of hold/knot on the string.
  7. How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: adım 7, 3 resimden 1. How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: adım 7, 3 resimden 2. How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: adım 7, 3 resimden 3.
    • Pull the knot.
    • Twist the tuning pegs in a counterclockwise rotation.
    • Twist towards the tailpiece.
  8. How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: adım 8, 1 resimden 1.
    • Cut any excess string with pliers.
  9. How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: adım 9, 1 resimden 1.
    • Place the tailpiece back by sliding it towards the headstock.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 5
Son 30 gün: 21
Her zaman: 218
