Ana içeriğe geç
How to Replace the Temple Tips of a Pair of Eyeglasses
Neye ihtiyacın var
  1. How to Replace the Temple Tips of a Pair of Eyeglasses, Temple Tip: adım 1, 1 resimden 1.
    • Put all separated parts of the eyeglass including the eyeglass frame, temple tip on a clean and flat surface.
  2. How to Replace the Temple Tips of a Pair of Eyeglasses: adım 2, 2 resimden 1. How to Replace the Temple Tips of a Pair of Eyeglasses: adım 2, 2 resimden 2.
    • Clean the temple and temple tip with alcohol wipes to make sure any glue residue is removed.
  3. How to Replace the Temple Tips of a Pair of Eyeglasses: adım 3, 1 resimden 1.
    • Drop a single drop of glue onto the end of the temple tip.
  4. How to Replace the Temple Tips of a Pair of Eyeglasses: adım 4, 2 resimden 1. How to Replace the Temple Tips of a Pair of Eyeglasses: adım 4, 2 resimden 2.
    • Slide the temple tip into the end of the metal part of the eyeglass temple until you feel the metal part hits the bottom of the temple tip.
  5. How to Replace the Temple Tips of a Pair of Eyeglasses: adım 5, 1 resimden 1.
    • Hold it together for around one minute to keep it in the correction position.
  6. How to Replace the Temple Tips of a Pair of Eyeglasses: adım 6, 1 resimden 1.
    • Using a hairdryer on high heat, heat the temple tip to shrink it for roughly 3-6 minutes.
    • For safety, wear thick gloves during this step. It can protect you from burning your hand by the hot air of the hairdryer.
Sonuç
Fixing a temple tip of eyeglasses is an uncomplicated process that you can do at home by yourself. Our instruction will have some steps, following:
2 farklı kişi bu kılavuzu tamamladı.
ZHEHAO GUO
187 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 85
Son 30 gün: 373
Her zaman: 13,074
